Sinking Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 09:44 AM   #1
Sinking Shed
Hi all!
I have a 14x16 garden shed that, while built fine, was not put on a solid enough base and has been slowly sinking in the rear over the last couple of years. I have jacked up the rear corners and inserted shims, but the problem seems to be the excessive water in the area (another issue).
So, this year I would like to jack up the shed and pull up the concrete blocks it is resting on. I would like to completely fill in the area with crushed stone, dig a some new footing areas and fill them with crushed stone, and set the shed back down - level with some good drainage. I would also like to put in three new 2x8 beams along the 16 foot length.
So, my question is about the stability of the shed. My plan was to jack up the shed, after I create a solid enough foundation so the jack doesn't sink into the ground while jacking, and place the shed on 6 jack stands about 6-8" above grade. Then I will have enough room to shovel the crushed stone under the shed and create new footings.
IS this going to be safe? or is there a better way to do this?
My other option would be to dismantle the shed (take off the roof, the walls and the floor), redo the area with the crushed stone, then put the shed back together, like a kit. Would that be easier or better?
Thanks a million!!
willise is offline   Reply With Quote
Old 05-04-2011, 10:08 AM   #2
Old School
Willie T's Avatar
I would be interested in hearing what you are expecting the crushed stone to do? Sounds like you intend for them to be your foundation.
Willie T
Old 05-04-2011, 11:52 AM   #3
Rewards Points: 256
Can you jack up the shed? Simple answer, I'm sure you can.
My concern is with your plan to "shovel crushed stone under the shed and create new footings"; the problem is the ground moving, not the cinder blocks, and stone won't fix the problem which is what I believe WillieT is getting at. Changing the drainage in the area would be the best bet, then dig true footings to put the shed on. However if you simply raise the shed and don't move it how can you get under it to dig the footings? My longer solution answer is move the shed and get your foundation right, then move it back. Or create a new foundation in a different area and move the shed onto it.
moneymgmt is offline   Reply With Quote
The Following User Says Thank You to moneymgmt For This Useful Post:
Willie T (05-04-2011)
Old 05-04-2011, 12:34 PM   #4
All Things Design
Def need to move the shed out of the way to do the job right, it will just be in the way.
If you can't have a concrete slab poured, I would dig and remove a good amount of the soil, add a 6-8 inch base of quarry process (that's a product we sell that is part crushed stone/part stone dust) it packs very well and won't shift at all. Then put the crushed stone on top of that for drainage. For optimal drainage the key is to have the final base the shed will rest on slightly higher so you can pitch the perimeter of the shed downward to prevent any collection of water.
Rock8Reno is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 12:35 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
