Old 01-22-2011, 11:18 AM   #1
Sinking garage floor
My unattached 1 car garage floor has cracked and sunk in the middle. So each side slopes toward the middle at a difference in elevation of approximately 5 inches. Can this be saved by pumping in concrete to lift it up, or does this sound like the whole thing needs repoured? The garage door has a 5 inch gap because of it. Haven't had an estimate yet....wondering what the cost would be.
smawgunner is offline   Reply With Quote
Old 01-22-2011, 11:25 AM   #2
011010100110111101100101
Sounds like you are in trouble. What size garage?
-- Joe
anesthes is offline   Reply With Quote
Old 01-22-2011, 12:04 PM   #3
-- Joe
It's 14 x about 24.
Old 01-22-2011, 12:40 PM   #4
firehawkmph's Avatar
I would look into tearing it out and seeing why it sunk so much and fix the problem before the new concrete is installed. Could be bad base originally settled, maybe a drain either in the garage or outside has gone bad letting water erode the base. Best to find out.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-23-2011, 08:00 PM   #5
Concrete & Masonry
Mud jacking could certainly be an option here. I would suggest calling for a few quotes to verify that it's possible, and then obviously you'll also get a precise estimate of cost.
jomama45 is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 11:09 PM
floor framing in garage chrishallowell Building & Construction 0 06-29-2010 09:04 AM
Garage Attic Floor Joists zacmac Carpentry 3 11-02-2009 10:07 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
