-   -   Sinking garage floor (http://www.diychatroom.com/f19/sinking-garage-floor-93093/)
smawgunner 01-22-2011 10:18 AM
My unattached 1 car garage floor has cracked and sunk in the middle. So each side slopes toward the middle at a difference in elevation of approximately 5 inches. Can this be saved by pumping in concrete to lift it up, or does this sound like the whole thing needs repoured? The garage door has a 5 inch gap because of it. Haven't had an estimate yet....wondering what the cost would be.
anesthes 01-22-2011 10:25 AM
Sounds like you are in trouble. What size garage?
-- Joe
smawgunner 01-22-2011 11:04 AM
-- Joe
It's 14 x about 24.
firehawkmph 01-22-2011 11:40 AM
I would look into tearing it out and seeing why it sunk so much and fix the problem before the new concrete is installed. Could be bad base originally settled, maybe a drain either in the garage or outside has gone bad letting water erode the base. Best to find out.
Mike Hawkins:)
jomama45 01-23-2011 07:00 PM
Mud jacking could certainly be an option here. I would suggest calling for a few quotes to verify that it's possible, and then obviously you'll also get a precise estimate of cost.
