Sinking Front Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 05:47 PM   #1
sinking front porch
I am trying to repair my front porch. It has two brick steps and then an aggregate landing. The landing has sunk two inches in the rear and is slightly raised in the front. I think the space underneath is hollow. I need some tips on how to replace the concrete slab. My idea is this: break up the existing. Lay rebar front to back approximately 4" lower than the finished surface. Lay corregated galvanize metal then pour in new concrete.
JTCollins74 is offline   Reply With Quote
Old 10-12-2011, 06:03 PM   #2
Rewards Points: 5,336
The base the landing was set on was not proper. Set the new landing on something better.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
JTCollins74 (10-12-2011)
Old 10-13-2011, 06:22 AM   #3
There is a process called mud jacking, where mud is forced under a slab to raise it. It is not suited for every situation but might work for yours. Consult someone that does that process.
Old 10-13-2011, 07:32 AM   #4
joed's Avatar
Rewards Points: 13,344
Fill the space with properly compacted fill. Don't try to bridge it with rebar.
Front Porch Flashing? kcrossley2 Building & Construction 7 07-23-2011 02:13 PM
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 12:58 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 03:12 PM
Sinking Front Porch gpet573 Building & Construction 4 06-02-2008 09:51 PM
