Single Rim Joist Rotted - Support? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2014, 02:45 PM   #1
Hello,
I'm currently repairing my front deck after I found it was not flashed properly. I discovered that the single rim joist has rotted in several sections.
My concern with replacement is does the inside joists need to be supported. Based on the crawl space the joists are resting on the sill, but still concerned if extra support is needed before removing the rim joist.
I have attached outside and crawl space pictures. Any advice on this would be appreciated.
Single Rim Joist Rotted - Support?-dsc02352.jpg   Single Rim Joist Rotted - Support?-dsc02353.jpg   Single Rim Joist Rotted - Support?-dsc02354.jpg   Single Rim Joist Rotted - Support?-dsc02355.jpg   Single Rim Joist Rotted - Support?-dsc02357.jpg
kromc5 is offline   Reply With Quote
Old 05-07-2014, 03:00 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Looks safe from pics. But then look at my avatar.
Robpo is offline   Reply With Quote
Old 05-07-2014, 03:30 PM   #3
Rewards Points: 2,034
Agreed. I too fear no heights, nor falls. But that sudden stop scares the "willies" out of me.
ED
de-nagorg is online now   Reply With Quote
Old 05-07-2014, 03:33 PM   #4
It would be fairly easy to build a temporary support for your joists, from a few concrete blocks stacked, with a stringer board running the length needed to support the joists temporarily, that way you could work the rotted rim out from above and below without fear of collapsing the remainder of the deck.
Ed
Old 05-07-2014, 07:04 PM   #5
Rewards Points: 430
No worries. Those joists ARE sitting on the sill and are not going DOWN. The main function of the rim joist or band joist along the sides of the house perpendicular to the floor joists is to keep the floor joists plumb and keep the from racking. In most cases the floor trusses are laid in place first and tacked to the sill with the rim following as the crew moves along and plumbs joists. Yes, the rim partially supports the floor above...to the tune of the thickness of the rim....but the rest is solidly sported by the trusses themselves. So you have a solid structure in place, replace the rotted rim, flash properly, and good to go. Ron
ront02769 is offline   Reply With Quote
The Following 2 Users Say Thank You to ront02769 For This Useful Post:
Msradell (05-07-2014), oh'mike (05-07-2014)
Old 05-08-2014, 09:40 AM   #6
I greatly appreciate the helpful comments, will proceed forward will update how it goes.
Thank you
Old 05-10-2014, 02:45 PM   #7
Rim Joist Replaced
Took us 4 hours to complete the replacement, flashing and new ledger is installed. I wonder how much time it would have taken the pro's. Reason I did this as CHI the local company quoted me $2400 to replace the one board, no flashing etc just remove the rim joist. Seems like they are wanting a little to much per hour, I appreciate the help and extreme savings.
Thank you
Old 05-10-2014, 02:53 PM   #8
And we thank you for allowing us to be of assistance, even if it was just via this forum.
Great to hear that you were successful at saving a lot of cash, and learned something as a bonus.
YOU'RE WELCOME
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
ront02769 (05-10-2014)
Old 05-11-2014, 08:40 AM   #9
Rewards Points: 236
lets see a larger pic of that.
Fix'n it is offline   Reply With Quote
Old 05-11-2014, 09:26 AM   #10
Rob
Robpo's Avatar
Rewards Points: 826
Old 05-11-2014, 09:29 AM   #11
Git-er-done. Whatever works.
ED
Old 05-11-2014, 09:30 AM   #12
Rewards Points: 236
that doesn't look that bad.
Old 05-11-2014, 09:44 AM   #13
Rob
Robpo's Avatar
Rewards Points: 826
Don't think OSHA would approve. We were putting ridge cap on because builder was from out of state and wouldn't come back to finish and his son went out and took the pic. It sat for months with no ridge cap. Just wanted to get it done. Thing is we have both taken OSHA and MSHA courses.
Old 05-11-2014, 09:58 AM   #14
kwikfishron's Avatar
Rewards Points: 586
At least when the guy on the metal roof starts sliding he has something to grab on to.
kwikfishron is online now   Reply With Quote
Old 05-11-2014, 10:01 AM   #15
Rewards Points: 236
lol, no, i don't think they would. looks pretty solid though. which guy are you ?
Please help! How to add floor joist to re support floor Spm8d6 Remodeling 9 03-27-2014 09:48 PM
rotted wood at bottom of porch support angusmdmclean General DIY Discussions 15 11-04-2013 05:33 PM
Ceiling Joist support beam bolini95 Building & Construction 2 01-20-2013 09:00 AM
Sill plate, rim joist replacement frkingz Building & Construction 0 05-11-2011 08:00 PM
How would you support pipe in existing joist space? wease Plumbing 18 02-06-2011 05:20 PM
