Single Coat Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2009, 10:53 AM   #1
Single Coat Stucco
Anyone have any experience with the single coat stucco by Quikcrete and other companies with the fiberglass additives? Thinking about using it on my home instead of the usual 2 or 3 coats since I'll be doing it myself and it will go a lot faster. Anyone? Good/bad/indifferent?
Harpoon is offline   Reply With Quote
Old 03-31-2009, 11:00 AM   #2
Rewards Points: 1,232
I would think you still want at least 2 coats. One base coat and one finish coat.
Also, it is a lot cheaper to just buy premixed mortar, Type S, and add a hand full of fibers per bag.
Premixed stucco, 80#: $13-18.00 bucks
Premixed Type S mortar, 80#: $5-6.00 bucks
Fiber mesh, 1.5# (enough to do 40 bags of mortar): $6-10 bucks.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 03-31-2009, 01:25 PM   #3
I called HD and I can bulk order a pallet of the single coat for $9 a bag (42 bags per pallet) so the price is pretty comparable.
Old 04-01-2009, 12:57 AM   #4
I haven't used Quickcrete's version but have used other FRS. We've done the base coat with a finish coat as well as scratch coat with brown coat then finish coat.
KHouse75 is offline   Reply With Quote
Old 04-02-2009, 10:46 AM   #5
Now you really got me thinking about this with the Type S mortar.
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 08:07 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 11:04 AM
