Simpson Joist Hanger Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 01:26 PM   #1
I'm building a floating deck and I'm using the LUS model joist hanger from Simpson. Instructions call for a 10D, 3" nail for a single 2x or I can use the #9 2-1/2" Simpson screws. Since I'm hanging the joists on a 2x8 rim joist, either of these options are too long. I want the joist to provide the required support but I don't want anything breaking through the backside of the rim joist, so just use 1-1/2" nails?
Makes sense to me, but just want to make sure.
Yes, this is my first deck.
OKDrew63 is offline   Reply With Quote
Old 08-11-2012, 02:11 PM   #2
Rewards Points: 3,130
I'm not familiar with that particular hanger, but I have never heard of a Simpson product that called for a regular 10d nail. Are you sure?
Old 08-11-2012, 03:59 PM   #3
Civil Engineer
Rewards Points: 4,780
Simpson joist hangers come in a variety of types. The LSU hanger takes two kinds of nails. The longer, standard 10d nails are installed at an angle, so a 3 inch nail does not typically break through the other side. You use Simpson 10d short nails (1.5 inches) for the face nailing holes ONLY. This is a source of considerable confusion, even among building inspectors and contractors, since the short 10d nails are typically sold right next to the hangers, and are called joist hanger nails, whereas in fact Simpson specifically states that to achieve the full rating of the hanger, you need full size 10d nails for the diagonal nails.
Daniel Holzman is online now   Reply With Quote
Old 08-11-2012, 04:05 PM   #4
Thanks for the clarification, that was the path I was leaning toward taking.
16' joist span question. MikeVila Building & Construction 9 05-06-2012 08:40 AM
new ceiling joist and ledger question Laura5 Building & Construction 8 03-01-2012 11:15 AM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
joist hanger nail size--confused edfromma Building & Construction 16 03-03-2010 02:18 PM
Joist question - sistering tpagel Carpentry 5 03-09-2009 08:11 AM
