Simple Wall Framing Question.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 04:08 PM   #1
Rewards Points: 1,910
Simple wall framing question..
I need to frame a simple long load bearing wall with only ceiling/roof load above. It will be typical construction with a sole plate, studs 16" oc and a double top plate. Since the longest plate material I can get is shorter than the wall length I will need to have at least one joint in each of the plates.
I know that I want to have the joints in the double top plate at least 4' from each other. Does it matter where these joints are located in relation to the studs? For example if the joint in the lower plate of the double top plate lands between two studs 16" oc is that ok? Or should the studs be doubled up at the joint so that both ends are supported by a stud?
Old 10-22-2008, 04:51 PM   #2
Framing Contractor
No, it doesn't. Put the joint anywhere you want.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-22-2008, 05:07 PM   #3
Thanks Joe! I know you're a professional framer and appreciate your taking time out to help us DIYers.
Old 10-22-2008, 05:10 PM   #4
Registered User
Termite's Avatar
I agree with Joe that it doesn't matter...Unless you have roof or ceiling loads landing in between the studs. If your loads stack directly in line with the studs, splice location is not an issue. If you have a splice between the studs and a rafter sitting between the studs, you'd need to add a stud to support the rafter.
Old 10-22-2008, 05:17 PM   #5
Well I guess I should have said I was going to use roof trusses 24" OC so no doubt that some will land between the studs.
Old 10-22-2008, 07:07 PM   #6
Registered User
Termite's Avatar
Then you must have two continuous top plates from stud to stud to take the trusses' loads. Instead of worrying about where to splice, I'd just stick a stud in where you break one of the plates with a truss overhead.
Old 10-26-2008, 03:15 AM   #7
Rewards Points: 1,016
Agreed - just add a stud where the plate in seamed.
Old 10-28-2008, 10:43 AM   #8
tracyp
yes it matters cut your plates even red number on your plate
framer1516 is offline   Reply With Quote
Painting 2-tone on a single wall question lmholmes11 Painting 3 07-18-2008 09:43 PM
Simple wall switch question LZCenter Electrical 8 06-30-2008 10:01 AM
knee wall question jscholl411 Building & Construction 7 10-10-2007 12:30 PM
Framing a Wall with a Soffit on Top sethr Building & Construction 2 05-21-2007 08:14 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
