Old 08-03-2011, 03:46 AM   #1
Simple Questions About Deck Stairs
I'm used to screwing or nailing treads down, but I've looked around and found some people that bolt them in from underneath using some type of metal hangers. I'd assume it's a preference, what do you guys prefer ? What's easier?
Also, I'm using open stringers so I was wondering if people prefer the treads to sit flush with the stringer, or overhang ? I was thinking of using a notched 4x4 bolted to the stringer on the bottom for my handrail, so I was leaning towards flush.
How would I determine the depth of the fasteners I'll need? I grabbed 5/4 wood that said it was for decking, but it appears that all of the existing wood is 2x6's I believe.
The last question is about connecting the stairs to the deck. I currently have two, one uses two stringers with a 2x6 nailed in between the stringers from each side, that 2x6 is then bolted into the frame of the deck.
The other uses three stringers and has a 2x6 either nailed or screwed (can't see it so I can't tell) into the stringers from the back. That 2x6 is also bolted to the deck.
Should I just use stringers attached directly to hangers on the deck frame?
TIA!
Briandl is offline   Reply With Quote
Old 08-03-2011, 06:53 AM   #2
Nails eventually pull loose, screws usually don't. Screwing underneath gives a cleaner finished look. But always use fasteners designed for modern PT chemicals, stainless steel is best.
Old 08-03-2011, 04:58 PM   #3
Coconut Pete's paella!
CoconutPete's Avatar
My stringers are screwed in from behind the 2x12 frame. They are also nailed on w/ brackets. Might be overkill, but so was the rest of the framing.....
My step overhangs the stringer just a little bit. Check w/ your building department, you might need an overhang, my town has their own weird rule about having to have an overhang.
CoconutPete is offline   Reply With Quote
Old 08-03-2011, 06:21 PM   #4
Thanks. Any other suggestions or expertise would be appreciated.
Old 08-04-2011, 02:54 PM   #5
Bump.
DIY'er vs Framer - Deck Questions cbzdel Building & Construction 3 07-05-2011 08:08 PM
simple roofing or shade for a deck? Clem2011 Roofing 12 04-23-2011 10:56 PM
deck stairs that fan out pjbrady Building & Construction 1 04-17-2010 03:05 PM
Adding Stairs To A Deck WBNC Building & Construction 19 08-06-2009 10:54 AM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
