-   -   Simple Questions About Deck Stairs (http://www.diychatroom.com/f19/simple-questions-about-deck-stairs-112803/)
Briandl 08-03-2011 03:46 AM
I'm used to screwing or nailing treads down, but I've looked around and found some people that bolt them in from underneath using some type of metal hangers. I'd assume it's a preference, what do you guys prefer ? What's easier?
Also, I'm using open stringers so I was wondering if people prefer the treads to sit flush with the stringer, or overhang ? I was thinking of using a notched 4x4 bolted to the stringer on the bottom for my handrail, so I was leaning towards flush.
How would I determine the depth of the fasteners I'll need? I grabbed 5/4 wood that said it was for decking, but it appears that all of the existing wood is 2x6's I believe.
The last question is about connecting the stairs to the deck. I currently have two, one uses two stringers with a 2x6 nailed in between the stringers from each side, that 2x6 is then bolted into the frame of the deck.
The other uses three stringers and has a 2x6 either nailed or screwed (can't see it so I can't tell) into the stringers from the back. That 2x6 is also bolted to the deck.
Should I just use stringers attached directly to hangers on the deck frame?
TIA!
Just Bill 08-03-2011 06:53 AM
Nails eventually pull loose, screws usually don't. Screwing underneath gives a cleaner finished look. But always use fasteners designed for modern PT chemicals, stainless steel is best.
CoconutPete 08-03-2011 04:58 PM
My stringers are screwed in from behind the 2x12 frame. They are also nailed on w/ brackets. Might be overkill, but so was the rest of the framing.....
My step overhangs the stringer just a little bit. Check w/ your building department, you might need an overhang, my town has their own weird rule about having to have an overhang.
Briandl 08-03-2011 06:21 PM
Thanks. Any other suggestions or expertise would be appreciated.
Briandl 08-04-2011 02:54 PM
Bump.
