Simple Question - Proper Direction Of Ceiling Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 09:18 PM   #1
Simple question - proper direction of ceiling insulation
Hi everyone... I have a quick question regarding insulating a ceiling. Is there a "proper" way the insulation should face? I've always insulated ceilings with the paper face down. It seems it would be much easier though if I just got up in the attic and rolled out the insulation - with the paper face up. No fighting gravity this way!! Is there anything wrong with doing it this way?
jizzle is offline   Reply With Quote
Old 01-07-2009, 10:00 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
It depends on where you live. The vapor barrier is on the warm side.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-07-2009, 10:08 PM   #3
Remodeling Specialist
The vapor barrier faces the living area but it most cases unfaced is preferred in attics. You want the moisture to leave your house through the attic.
Use unfaced in your attic, unless you have a very low moisture environment.
Baron is offline   Reply With Quote
Insulation question Outbacker HVAC 16 12-29-2008 10:54 PM
Insulation question..... v12357 Building & Construction 5 09-14-2008 09:04 PM
basement insulation question benp Building & Construction 2 03-24-2008 11:46 AM
Basement ceiling insulation floxy Building & Construction 5 01-07-2008 07:37 PM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 12:52 PM
