Old 05-01-2012, 10:51 PM   #1
Simple lean to shed roof
I am building a simple shed roof with 2x10 joists 32 in. o/c with 2x4 purlins 30 in. o/c covered with 29 ga. galvanized steel roof panels. The joist are 18 ft. long and the posts are spaced 20 ft. apart. What would be the most cost effective material to use for the header beams? I have considered multiple 2x12 joists nailed together to micro lams. What are your thoughts on this? Thank you..
HANKNJAKE is offline   Reply With Quote
Old 05-02-2012, 01:06 PM   #2
STAFF
BigJim's Avatar
20 foot span is a little far for a header. Is this a shed or living quarters? Where do you live, are there any snow load concerns?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 05-02-2012, 03:53 PM   #3
It is just a roof covering to keep the weather off stored parts. It is in the Riverside Ca area with no snow and little rain. It will be 120 ft long by 18 ft wide. I am thinking three 2x12's nailed together should be enough to span the distance and carry the light load. What do you think?
Old 05-02-2012, 05:54 PM   #4
Framing Contractor
Doesn't matter what anyone thinks. People here should not be sizing beams for you over the internet or making you feel better about what your thoughts on what size beams you should use. Call your building department or an architect or engineer and ask them.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-02-2012, 07:40 PM   #5
GBrackins's Avatar
I agree with Joe Carola, you should contact a professional engineer or architect. I question your rafters based upon span and spacing. No sense spending the money to build something it if won't stay up. worth the money to have a professional design it properly.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-02-2012, 08:01 PM   #6
Even that joist spacing sounds off to me, I would go no more the 24".
Insulating/Vapor barrier/Venting a 2/12 pitch Shed Roof with Cathedral Ceilings cmlarsen Insulation 6 12-21-2011 10:50 PM
No starter strip used on shed roof install? waterskier_erie Roofing 4 10-31-2011 09:25 PM
add shed roof to gable roof lucy1 Roofing 0 10-30-2011 09:31 PM
Shed roof construction questions wombosi Building & Construction 3 10-28-2011 11:01 PM
Footer size for a monolithic patio that can support simple roof seth Building & Construction 2 05-19-2009 10:19 PM
