Similar Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 12:31 PM   #1
Similar Garage
Hi first time here...I have a similar garage in which i would like to clean up and use as a pool table room. I am getting a new door installed with a new Jack opener which will eliminate the old style Genie which is attached from the center of my garage to the door. I am have a few 2 x 4s spanning from the back of garage to over the header of the garage door. There are 2 braces (1x6) that form an "X" if you look upwards. Does anyone know why these were used and can they be removed if i double up on the 2 x 4's mentioned above? I see that in Brandonlaundry's these are not used.
tenmoses is offline   Reply With Quote
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
Rewiring a garage Vertigo50 Electrical 6 11-17-2009 10:26 AM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
