Silly Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 08:13 AM   #1
Rewards Points: 121
Hello all. Have found answers to most questions I have here searching, but not this one, maybe it's too simplistic.
I'm renovating a 1982 house, about to put new drywall on an exterior wall that has R11 batts, which are fine. There are a few places where the studs are only 6-8 inches or so apart, near the corners, windows, etc. In these places there is just loose fiberglas stuffed in. Is there a better way to insulate these small areas? With some expanding foam or something similar? Or should I just not worry about it and leave the stuff that is there? Trying to get everything as tight and warm as I can.
The walls are 2x4 with sheathing and cedar lap siding and in the Atlanta area if it matters.
JoeLena is offline   Reply With Quote
Old 12-05-2010, 08:24 AM   #2
the Musigician
DangerMouse's Avatar
Hi Joe... if you can AFFORD it, I think sprayed in foam is always the best way to insulate most areas.
DM
Old 12-05-2010, 08:29 AM   #3
Rewards Points: 121
Thanks DM. I guess what I wanted to ask for these small areas would using a couple of cans of the expanding spray make sense, or be a waste of money?
Old 12-05-2010, 08:40 AM   #4
the Musigician
Not a waste.... but I'd advise using the blue cans if you use GSF.
They expand less as they set..... you don't want TOO much pressure as it sets, it could bow walls.
DM
Old 12-05-2010, 10:16 AM   #5
R11 isn't much insulation. You must have 2x4 walls. What concerns me is that there is an inadequate vapor barrier. Before you put the drywall up, make several cuts in the insulation's face paper and then put a continuous sheet of 6mil poly over it. Install the drywall and cut the plastic where it overlaps the windows afterwards
mrgins is offline   Reply With Quote
Old 12-05-2010, 10:25 AM   #6
Rewards Points: 121
They are indeed 2x4 walls. I assume I could get R13 in there, but most likely wouldn't be worth the cost?
I can put the plastic up. I plan to re-side the house in a year or so, would it be better to wait and wrap the outside? Will the plastic on the inside have any effect then? Thanks.
Rafter vents & insulation question k.kuenn Roofing/Siding 15 01-29-2011 11:34 PM
yet one more insulation question Mike in Arkansas General DIY Discussions 6 11-11-2010 09:47 PM
Insulation question Lockeset Building & Construction 4 11-10-2010 05:16 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
