#1 |
Sill rotten on a mobile home!
ok the mobile home was given to me by my mom. its 26yrs old. we are totally redoing all the floors except kitchen and it was redone last year. we are pulling the presswood out and replacing it with Advantech 3/4 inch. my major problem is the entire sill on the back side the trailer is gone! the end one so far looks good... how do I replace it... we have the siding pulled back and under pinning down... on the other side the trailer is a building attached to it that has a top do not know about that sill yet. can these be replaced... help need advice... I will try to upload pics in the morning.... I have a small budget... so I can't afford to hire someone expensive.
#2 |
Going to need that picture.
It's not looking good for you one this one. |
#3 |
Are the studs good?
How about the joists under this sill? |
#4 |
so far the joist going across haven't been that bad... the studs in the one place that I thought it would be bad bc the sill was gone, the stud was fine... there is a few joist that I am going to sister a joist beside it bc it is showing signs of beginning to get a little weak but still sound. Pics will come some time today....
#5 |
here are the Pics I promised
#6 |
By small budget you mean like say $100,000.00?
Should not take that much. Basically - carefully take of the siding, temporary support roof as needed, cut out rotted areas, put in new stuff, put on house wrap, put siding back on. Is there no sheeting on that? Just the metal on the studs? |
| The Following User Says Thank You to mae-ling For This Useful Post: | helloitsme21 (09-25-2012) |
#7 |
By small budget you mean like say $100,000.00? No More Like 3,000.
Should not take that much. Basically - carefully take of the siding, temporary support roof as needed, cut out rotted areas, put in new stuff, put on house wrap, put siding back on. How do I support the roof? Is there no sheeting on that? Just the metal on the studs? No Sheeting ... its just metal Siding, Suds, insulation, and paneling. Next Questions How to prevent this from happening again? How can I insulate the flooring without replacing the plastic... What about installing the Ridged Foam Board down under the Advantech? |
#8 |
anyone?
#9 |
Insulating the floor would probably be similar to insulating a dirt floor crawl space. I would probably consider trying to house wrap the underside also, following the contours, then use the wire hangers to suspend fiberglass bats between the joists. Finally i would lay a thick plastic on the ground underneath as a vapor barrier to control the moisture coming out of the ground. The problem I could see with rigid foam is that it will trap any moisture between the floor boards and the foam and encourage the floor boards to rot again.
As fat as the construction and repair stuff, I'm going to leave that to someone else, unfortunately, I'm not very knowledgeable in that stuff. |
#10 |
This is out of my area of expertise.
I thought I once saw a forum for mobile homes? |
#11 | |
Sill rotten on a mobile home!Quote:
#12 |
I've looked at videos and none of them show what I need... I know how to rip out floors but I don't know what I need to do to replace that sill.. we have removed the floor already so right now there is no sill and floor joist r just hanging there.
#13 |
This sill you are talking about where is it supposed to be.
Bottom plate on wall? Rim joist on end of joists? Or maybe those metal straps go down over end of joists and no rim joist? There is no foundation? It is just on blocking? When I hear sill I think of a 2x6 (or wider) on top of a concrete wall that the floor joists sit on. sorta like this. |
#14 |
I think you're talking about your Rim Joist. The outside joist of your floor framing ( the other joists connect to ). It looks like a 2x6 (1 1/2" X 5 1/2" ). You're so close to the ground that it should be treated (pressure treated wood). They usually break on center of a joist.
if I'm right let us know, there's some other stuff you'll need to know, tham |
#15 |
OP, can you take some additional pictures from the distance so that we can see how your mobile home is positioned in relation to the surrounding dirt (sitting on a hill/grade, on a dip, etc.)
I do not think it is a good idea to lay down plastic barriers on the ground without first understanding how rain and ground water will be managed (don't want a pool of stale water under my home to attract animals and be a mosquito breeding ground!). I would also stop remodeling the rest of the home until you can get this foundation and floor joist/rim band issue squared away first When you look around the perimeter of your home, can you describe how it is resting on the ground? Is the mobile home sitting on cinder blocks in certain places, or do your floor joists make direct contact? I am not a bug expert but some of those wood particles seems like you had termite issues so you may have to address that problem as well. Post back and let us know? |
| The Following User Says Thank You to allthumbsdiy For This Useful Post: | notmrjohn (09-27-2012) |
| Display Modes | |
| Replacing rotted sill plate in 120 yr old home | M.dizzle | Building & Construction | 16 | 02-29-2012 03:53 PM |
| Mobile Home Electrical Panel Replacement | rrolleston | Electrical | 2 | 01-28-2012 06:27 PM |
| putting mobile home on an old house foundation | rkr1991 | Building & Construction | 3 | 08-19-2010 10:20 AM |
| venting from mobile home through new metal roof | jeanmoon | Roofing/Siding | 2 | 07-27-2010 09:39 PM |
| running electric under mobile home | brianbrianj | Electrical | 6 | 05-09-2010 04:49 PM |
