Sill Replacement - Length Of Sections - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 09:25 PM   #1
Rewards Points: 27
sill replacement - length of sections
Need to replace the sill of my ranch. Just some parts. The easiest way to do this is obviously to jack 3 or 4 individual joists and replace a section at a time.
Is there anything wrong with doing 5 or 6 feet sections like that? Obviously for original construction, much longer boards were used. When ease of access was taken for granted....
Any tips or warning appreciated.
bamaranch is offline   Reply With Quote
Old 04-26-2010, 10:16 AM   #2
Rewards Points: 27
clarification - sill plate
Hi all, a quick clarification. It's the "sill plate", I'm replacing. The board on the concrete block foundation that the wall sits on.
Original boards used were very long - 10 foot 2x6s. I'm wondering if I can replace it using smaller sections (4-6 feet) which makes access easier.
Thoughts appreciated.
Old 04-26-2010, 11:08 AM   #3
Rewards Points: 1,910
Use as long as you can but you will end up using shorter lumber than the original. Depending on where you are (wind loads, earthquake considerations etc.) you'll need to work out how your going to attach the new sill lumber to the foundation. Check with your local building department on correct methods of attachment.
Old 04-26-2010, 11:10 AM   #4
kwikfishron's Avatar
Rewards Points: 620
Yes you can.
kwikfishron is offline   Reply With Quote
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
Replacement window sill almostgreen Carpentry 1 10-11-2009 06:44 AM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 12:19 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
