Old 07-18-2012, 08:25 AM   #1
Sill replacement after foundation work
Guys - I just had a section of foundation repaired/replaced. The mason left the new foundation 1.5 shorter than the original. I've had to add another sill plate and make a repair around the basement window. I'm attaching a photo of the repair. You guys think this will work? Its a 2x8 sill with a vertical 2x8 next to the window to act as a king stud. If not, I will have to have the mason return and put 1.5 inch of concrete to make up the difference.
lslapshot is offline   Reply With Quote
Old 07-18-2012, 08:34 AM   #2
joed's Avatar
Look fine except I think I would have used pressure treated in contact with the concrete.
Do not PM with questions that can be asked in a forum. I will not respond.
rotten sill replacement Guillemot Building & Construction 0 09-24-2011 10:59 PM
Replacement window sill almostgreen Carpentry 1 10-11-2009 07:44 AM
Sill Plate shim replacement and gaps kenglish Carpentry 6 05-22-2009 06:00 PM
Sill Flashing for Replacement Windows nuckphoto Remodeling 2 05-19-2009 02:10 PM
Sill Plate replacement Thanks Termites :-O winglover1 Carpentry 2 05-05-2009 10:23 AM
