Sill Plate Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2008, 09:57 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Sill Plate size
I'm building up after tearing down the sunroom on my house. I've filled the cells in the block foundation and in the next couple of days I'll be ready to start building. The sill plate I pulled out was 4x8, I was planning to replace with 4x8 PT. Unfortunately, 4x8 PT is unavailable. I'd like to keep the bearing surfaces the same throughout the house, so I don't have to build some wanky support posts.
My options are 4x6 PT, 2-2x8 + 1/2" ply, or maybe I don't need to match the level of the existing sill and just use 1-2x8 PT.
What's my best choice?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-13-2008, 11:41 AM   #2
Registered User
Termite's Avatar
Are your floor joists bearing directly on the sill plate or is something else going on? If the joists are bearing right on it, I'd consider just doubling a 2x8 and bolting it down, and making up the 1/2" thickness on top of the floor joists with 1/2" plywood strips or even the addition of 1/2" plywood or OSB sheathing to the 3/4".
I remember wondering where on earth you were going to get 4x8 when you posted the question about overlapping the corners and anchor bolts. Figured you had it covered.
Old 09-13-2008, 12:16 PM   #3
I have gas!
Thanks kc, there's nothing else going on, joists are directly on the sill plate. My biggest concern for wanting to keep the same dimensions as existing sill is when I build the support posts, I would have to accommodate the difference in thickness between the basement girder and the new sill.
Also, HD doesn't stock a .6 PT product for concrete contact, they only go to .4 for ground contact. Is .6 PT a regular stocked lumberyard product. I know, I know, use a real lumberyard, but HD has store hours more conducive to homeowners.
I got a bit delayed when I found discovered a broken block.
I found 4x8 PT listed on several lumberyard websites so I didn't think it would be hard to find. I don't know if it ever was a stocked item but now it's special order.
Old 09-13-2008, 01:00 PM   #4
Registered User
Termite's Avatar
.4 is for concrete contact, .6 is for direct burial. ".4" represents .40 pounds of treatment per cubic foot of wood. .6 is better...Use it with confidence.
Old 09-13-2008, 05:27 PM   #5
Rewards Points: 5,336
You should be using a sill seal over the block and not resting the wood directly on the cement surfaces. It's a foam product about 1/4" thick that comes in rolls. It will also fill gaps in an uneven foundation wall.
Ron
Old 09-15-2008, 05:48 PM   #6
I have gas!
Took a few phone calls but my local LY found 4x8 PT. A bit pricey but construction is a lot easier when everything is on the same plane.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 04:07 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 07:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Sill plate and pre-hung door sithappens Building & Construction 4 01-27-2008 07:18 AM
