Sill Plate And Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 06:21 PM   #1
Rewards Points: 396
sill plate and sheathing
When you go to install your foundation sill plate should you recess it in the thickness of your sheathing or should it just be installed flush with the outside of the foundation wall then the sheathing overhang the foundation wall?
detroittigerfan is offline   Reply With Quote
Old 08-29-2013, 06:39 PM   #2
Rewards Points: 13,968
Sheathing should run past the foundation or air and insects can get in.
Old 08-29-2013, 08:11 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
in my area we hang the sill plate about 1/4" out from the exterior face of the foundation. The bottom of the sheathing is typically installed about an inch lower than the top of foundation.
if your sheathing is installed on top of the foundation it can wick water up into the sheathing.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-29-2013, 09:30 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,244
yes and no to whats been said.. the sil should be installed so your walls are still square.. the overhang may vary along hte length of the foundation depending how striaght the forums were when teh concrete was placed
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
joecaption (08-30-2013)
Old 08-29-2013, 09:40 PM   #5
Rewards Points: 396
Ok then what is used to cover the ends of the sheathing since there overhanging the foundation wall? Drip edge?
Old 08-29-2013, 11:22 PM   #6
GBrackins's Avatar
nothing typically
Gary
Old 08-30-2013, 05:41 AM   #7
That's why the sheathing needs to be at least 6" above grade so the splash back does not get to it.
Old 08-30-2013, 03:59 PM   #8
kwikfishron's Avatar
Rewards Points: 774
Although I've never seen it done you could install wider sill seal and let it hang to the outside, install the sheathing allowing the ss to fold down and trim off flush if that gap bothers you that much.
kwikfishron is online now   Reply With Quote
rotten sill replacement Guillemot Building & Construction 0 09-24-2011 09:59 PM
semi exposed sill? cbzdel Building & Construction 7 09-18-2011 02:41 PM
Illustrated nailing schedule? cortell Building & Construction 6 11-29-2010 09:26 PM
wood framing-screws or nails? ron0805 Carpentry 8 10-15-2009 10:20 PM
Confused with code requirements about structural sheathing. Clutchcargo Building & Construction 19 11-20-2008 09:17 AM
