Old 10-12-2009, 05:21 PM   #1
Default Sill plate and rim joist question
Hey All-
Wondering if someone can help me identify something. I'm getting ready to replace the shoddy batt insulation around the sill plate in our unvented crawl space with foam board, caulk and expanding foam. But I've discovered that there is some kraft paper running between the sill plate and the rim joists. Does anyone know what this is for? It hangs over the top of the foundation wall.
I don't think it's a termite barrier, or capillary break. Is it supposed to hold the batt insulation in place? And how do I work around it when installing the foam board on the rim joist and sill plate? It won't be very air tight if I leave the paper hanging out.
Thanks much for any insight!
See the attached pictures if that helps.
House is 20 years old in the land of WI.
bhasty is offline   Reply With Quote
Old 10-14-2009, 04:09 PM   #2
Question
No one has any idea on this? Or is this just a bonehead beginner question?
Thanks in advance!
Old 10-15-2009, 08:48 AM   #3
gravity always wins
If it's just plain craft paper, it's not doing anything. Tear it off. Guys used to put tar paper between the sill plate and the masonry to stop moisture (before sill sealer and treated lumber sills) from wicking into the wood. I have no idea what plain craft paper would do between the sill and rim joist.
Old 10-15-2009, 04:07 PM   #4
Question
Well, after closer inspection, I see that it's not just regular kraft paper. It's got two layers of paper with some wax or tar substance in-between. And it's installed between the sill plates and joists, not between the plate and masonry.
Still okay to remove the excess? I would think leaving it there would just provide another surface for mold to rest.
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next thing on our list is going to be the garage band joist air barrier. What that is... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next one that we are going to cover on this list is going to be the air barrier and all... Read More »
Your sunroom is could be sitting empty most of the time, because it's too hot in the summer and too cold in the winter. Your sunroom can become a place for year-round enjoyment with a few easy steps. Imagine it as a haven--a place to sit and read, eat or... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about these arched windows like this. Okay we've put... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
