Sill Plate Replacement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 06:06 PM   #1
Question
sill plate replacement?
I seem to have a problem with the sill plate on one end of the house lifting up from the block foundation in the basement about 1/2 inch. it only seems to be lifting up on the inside of the basement, not the outside of the house. it doesn't seem to be rotten that I can see. any advice or suggestions what might be causing this and solutions to fixing this would be greatly appreciated. thanks, the sill plate is about 14 ft. long.
lpstudio71470 is offline   Reply With Quote
Old 02-02-2010, 06:47 PM   #2
Civil Engineer
Rewards Points: 4,694
I would check the elevation of the sill and the block with an accurate level. It may be that the block is settling the 1/2 inch rather than the sill lifting 1/2 inch. Only a very careful survey will tell. The fix will be quite different depending on which element is moving.
Old 02-02-2010, 07:55 PM   #3
sill replacement?
thank you for your reply, Dan. I don't believe the block has settled because the sill is sitting on top of it on the outside, only on the inside is the sill lifting up off of it, almost like it is warped. but I see no water damage.
Sill Plate shim replacement and gaps kenglish Carpentry 6 05-22-2009 05:00 PM
Sill Plate replacement Thanks Termites :-O winglover1 Carpentry 2 05-05-2009 09:23 AM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 12:19 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
