Sill Plate Repair And Joist Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 09:27 PM   #1
sill plate repair and joist repair
is it possible to repair or replace sill plates and also joists which need to be replaced along one wall . house sits on brick foundation. how do i find someone that does this type of work
Last edited by sandra barrier; 10-08-2010 at 09:30 PM. Reason: added additional information
sandra barrier is offline   Reply With Quote
Old 10-08-2010, 09:50 PM   #2
steveel's Avatar
Good question, Sandra, I've been wondering the same thing
When the new sills go in, do you have to open up the wall cavity to drill down to set anchors?
steveel is offline   Reply With Quote
Old 10-09-2010, 01:05 AM   #3
Sill replacement is a common job on old homes, although not so much of a DIY task unless you have the correct tools and some help.
1910NE is offline   Reply With Quote
Old 10-09-2010, 12:05 PM   #4
Any framing/remodelling carpenter should be able to do this work. Check with your local ordinances to see whats required for anchoring
mrgins is offline   Reply With Quote
Rim (Band) Joist Repair?? w/Pics Ruger141 Building & Construction 19 08-24-2010 11:51 AM
Deck - Header Joist Repair w/ pics DawnMarie Building & Construction 3 06-14-2010 09:25 PM
How to repair floor joist when sistering is not an option jmagee3d General DIY Discussions 2 06-05-2009 03:33 PM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 01:19 PM
Joist Repair SuperPlumber Building & Construction 3 06-12-2008 04:50 PM
