Sill Plate Hold Down Bolts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 10:51 AM   #1
Rewards Points: 121
Sill plate hold down bolts
The sill plate hold down bolts extend about 1" above the sill plate and will interfere with the floor joist installation. What is the best method to recess the nut and washer into the sill plate - or is there a better solution - maybe double up the sill plate? Thanks.
jrepp44 is offline   Reply With Quote
Old 11-08-2012, 02:39 PM   #2
Rewards Points: 121
While researching this topic I came across this website - looks like a translation from english to chinese then back to english?
http://lighting-electrical.org/Wall-...ll-Sill-Plate/
Old 11-08-2012, 03:04 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
notch the bottom of the joist. do not recess the anchor bolts washer and nut into the plate. building codes typically require a nominal 2x (1-1/2") plate. if you recess the washer & nut you no longer have a 1-1/2" plate at that point.
you are allowed to notch the ends of a floor joist 1/4 the depth of the joist (see link for diagram) http://publicecodes.cyberregs.com/ic...9_5_par030.htm
hope this helps
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-08-2012, 03:18 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,352
thats useless. that method is only good for partition walls on a slab inside.
for a mud sil you have to have 1/2" anchor bolts or 1/2" x 7" wedge anchors into the foundation wall. this is the only connection to the foundation for the rest of the house keeping it attached.
anchor bolts are placed when the concrete begins to setup after being poured. wedge anchors (red heads) are drilled out for with a sds hammer and driven into fully cured concrete then tightened with a ratchet or impact gun.. 1/2" threaded rod can also be used in conjuction with 2 part epoxy made for such an application.. hilti makes this product
woodworkbykirk is online now   Reply With Quote
Old 11-08-2012, 03:56 PM   #5
GBrackins's Avatar
Wood not sure I'm following, are you saying recessing don't work, or the notch don't work?
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
mae-ling (11-08-2012)
Old 11-08-2012, 06:54 PM   #6
sorry bout that gb.. the useless comment is about the original posters video using 3" stikers. when i responded to the thread the o.p. was the only post up
notching is perfectly fine or even shifting the joist. more often than not a large notch wont affect the bearing of the joist it may slightly weaken the connection at the rim joist though. but nothing to be worried about
Old 11-08-2012, 06:59 PM   #7
GBrackins's Avatar
whew! thanks Wood .....
didn't see the video, will have to go back and check it out
Gary
Old 11-08-2012, 07:50 PM   #8
U can waste ur time doin stupid bull**** and weakening the structure, or u can just put the joist right beside it on either side
ninjahero is offline   Reply With Quote
Old 11-08-2012, 09:20 PM   #9
AHH, SPANS!!!
Rewards Points: 1,166
just notch joists around the bolts, there should still be plenty of bearing for the joist as it sits on the sill plate
hand drive is offline   Reply With Quote
Insulating Sill Plate garyc Insulation 3 03-21-2011 09:02 AM
new mudroom "Attaching sill plate to concrete patio" wildonewest Building & Construction 2 11-09-2010 12:10 AM
How much Joist sitting on Sill plate? scott j Building & Construction 8 02-03-2010 10:00 AM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 08:03 PM
Req'd treated sill plate if I use Glulam seat ? yddkdd Building & Construction 4 07-16-2009 09:55 PM
