Sill Plate - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 09:50 PM   #31
Rewards Points: 940
In my neck of the woods, we leave the slab at least 4" above grade and have either bolts or straps installed every 4' or so, and within some distance of every opening.
On a 24 wall, I just frame up two 12' walls and lift them over the bolts.
It doesn't take a rocket scientist. You don't have to spend much time before you can figure out to put a piece of something under the sill plate for it to slide on, then position the wall over the bolts and pull out the blocking.
Obviously, you don't what the bolts to stick up over 2", just enough to get a washer and nut on them.
So get some 2" pvc and cut it into small pieces and put it under the wall on the ground, tilt the wall up, slide it in place, pull out the pvc, and you are done.
We put the sill sealer underneath as well.
I haven't seen any of this business of the 2 sill plates and a bottom plate.
cleveman is offline   Reply With Quote
Old 08-26-2013, 08:01 AM   #32
DIY staff
Rewards Points: 7,174
Originally Posted by jomama45 View Post
NOOOO, DON'T GIVE THE DIY'ER's THE WRONG IMPRESSION!!!!!!
The "grout" you'll find in the HD concrete section is generally non-shrink/anchoring/"precison" grout. It's actually mostly intended for concrete use, but it can be used "ON" block for a situation such as leveling under a sill plate. You certainly don't want to use it INSIDE as block core fill though, it's WAAAAY too strong for that......
Sorry, I'm no mason ---the tool I use for most concrete and masonry?
A telephone---" Hello, this is Mike, could you come to the job and price out some concrete work?"----I
hand drive (08-26-2013)
Old 08-26-2013, 08:54 AM   #33
Rewards Points: 396
why cant you use concrete for that? Why does it have to be grout?
detroittigerfan is offline   Reply With Quote
Old 08-26-2013, 09:11 AM   #34
AHH, SPANS!!!
Rewards Points: 1,166
concrete will crack and compress easier than the harder to crack non shrink grout
hand drive is offline   Reply With Quote
Old 08-27-2013, 09:22 PM   #35
Concrete & Masonry
Rewards Points: 530
I'm a little confused at the question, but you actually DO want to use grout in block cells to encase the vertical rebar for strength. You just don't want to use non-shrink grout, as it's waaaaay too strong. Generally, block cavity grout is designed to be in the 1500-2500 psi range, where non-shrink can exceed 10,000 psi strength. When the strength of the grout exceeds the strength of the block (somewhere between 3500-6000 psi typically) you create more non-favorable issues......
jomama45 is offline   Reply With Quote
Old 08-27-2013, 09:22 PM   #36
Concrete & Masonry
Rewards Points: 530
Technology is amazing, isn't it? Used to be you had to drive to the corner tavern to get a hold of your mason...............
The Following 3 Users Say Thank You to jomama45 For This Useful Post:
GBrackins (08-27-2013), kwikfishron (08-27-2013), oh'mike (08-28-2013)
Old 12-30-2015, 12:23 AM   #37
Rewards Points: 51
Question
Originally Posted by Solarboy View Post
The double sill plate is the way to go. Use treated for the bottom, bolt it to the foundation, build the walls on the slab and tip up into place. They aren't so heavy you need a crane unless they are real long...a typical garage wall can be tipped up with two people.
Using a double sill plate is it normal to have the anchor bolts also bolt down the top sill plate (bolt both sill plates and concrete together) or is the top sill plate only drilled so that it fits over the anchor bolt nuts then nailed to the bottom sill plate?
deepstuff is offline   Reply With Quote
Old 12-30-2015, 02:51 PM   #38
Concrete & Masonry
Rewards Points: 530
I can't speak for Canada, but "here", this approach is far more common.
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 11:33 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 04:07 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
