Sill Plate - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 05:12 PM   #16
Rewards Points: 396
Originally Posted by woodworkbykirk View Post
same difference.. either way it has to be done as i stated
same difference? How is a the slab and foundation wall the same? explain.
detroittigerfan is offline   Reply With Quote
Old 08-24-2013, 05:47 PM   #17
DIY staff
Rewards Points: 7,174
Kirk---If the foundation is level enough to shim and grout the treated plate, then stick framing is not needed----
You are right---if the treated bottom plate is not level--then the chalk line over head is needed to mark each stud----
Old 08-24-2013, 07:04 PM   #18
kwikfishron's Avatar
Rewards Points: 798
I've never stick framed garage walls. Frame the wall and lift it over and on the bolts.
If you're worried about the foundation wall not being level for the garage what's that say about the rest of the house? I've seen more issues with foundations being out of square than not level.
Maybe it's different with blocks, everything in the NW is poured.
kwikfishron is online now   Reply With Quote
Old 08-24-2013, 07:13 PM   #19
Rewards Points: 396
if the foundation wall ends up not perfectly level is it ok to shim the sill plate?
Old 08-24-2013, 07:25 PM   #20
Rewards Points: 798
If I knew the foundation wall wasn't level I'd stick frame it but there's no reason a new wall shouldn't be level.
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (08-24-2013)
Old 08-24-2013, 07:31 PM   #21
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
around here most of the residential foundations not only arent square but their not level either. the worst ive seen recently was 2 1/2" out of level. so the knee walls had to be stick framed..
personally i dont like shimming plates. id rather the sil plate be hard to the foundation than have to fill underneath it.
no one here uses block for foundations, the only time their used is for fire walls in townhouses and commercial spaces.. all the foundations are either panel forming or icf
woodworkbykirk is offline   Reply With Quote
Old 08-24-2013, 07:31 PM   #22
DIY staff
It's rare for a foundation to be out of level beyond shimming----if the shims are thicker than the sill seal--then grout must be poured under the gap.
I've never had to stick build a garage----but we have always had good concrete companies do the foundations.
Old 08-24-2013, 07:48 PM   #23
Rewards Points: 798
That's pretty bad Kirk, I'd surely blow a gasket if that was common place.
Old 08-25-2013, 10:00 AM   #24
Rewards Points: 396
I have a question that I have meant to ask. When you refer to grout are we talking about the same product for tiling?
Old 08-25-2013, 10:14 AM   #25
AHH, SPANS!!!
Rewards Points: 1,166
non shrink grout...
hand drive is offline   Reply With Quote
Old 08-25-2013, 06:03 PM   #26
DIY staff
Sort of---in the bagged concrete section of the store you will find masons grout---same sort of product---but cheaper and not so colorful
Old 08-25-2013, 06:25 PM   #27
in new construction its common, especially in production settings.. .
we do all of our own footings and foundatoins ourselves with nudura icf block.. both our footings and foundations are poured to a laser level shot elevation. so everything works out to within 1/4"
Old 08-25-2013, 06:50 PM   #28
Rewards Points: 396
What do you use grout for in masonry work?
Old 08-25-2013, 07:01 PM   #29
DIY staff
It is pourable--so it gets poured into the holes of cinder blocks to create a solid block and anchor in any rebar---among other things---
Old 08-25-2013, 07:08 PM   #30
Concrete & Masonry
Rewards Points: 620
NOOOO, DON'T GIVE THE DIY'ER's THE WRONG IMPRESSION!!!!!!
The "grout" you'll find in the HD concrete section is generally non-shrink/anchoring/"precison" grout. It's actually mostly intended for concrete use, but it can be used "ON" block for a situation such as leveling under a sill plate. You certainly don't want to use it INSIDE as block core fill though, it's WAAAAY too strong for that......
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
oh'mike (08-26-2013)
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 10:33 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 09:11 AM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 03:07 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
