Sill / Pan Flashing Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 02:55 PM   #1
Rewards Points: 270
sill / pan flashing questions
hi - will be installing new patio door and a couple of windows into camp building (new construction) - been reading a lot of different opinions on various options for flashing / waterproofing, including quite a bit about the latest peel-and-stick flashing tapes (bitumen, butyl, etc.)
this building has no housewrap (exterior is stained plywood panelling and will likely remain that way for several more years). The door / window have integrated brick mold (no flanges). Wondering what the best way is to protect the rough opening prior to installing the units (what to use for sill / pan flashing, what to wrap around the jambs in the rough opening, etc.) as well as how to best seal the brick mold to the sheathing (double sided stuff like Duponts Straightflash VF, or just silicone between brick mold and sheathing, or caulking around the brickmold once the window is installed, etc....?) seems like there are quite a few ways to go at this...
thanks
-randy
rtoni is offline   Reply With Quote
Old 07-09-2008, 04:23 PM   #2
There are commercially available sill pans. Just silicone it down to the underlayment. As for the brickmould, a good bed of silicone again, on the backside of the mould, and then finish with a bead around the perimeter.
My 2 cents
Brown Dog is offline   Reply With Quote
Old 07-10-2008, 10:00 AM   #3
Rewards Points: 270
Thanks Brown Dog - i appreciate the advice
Checked a couple of the local bldg stores and not having much luck so far finding prefab sill pans - I don't have the tools to try to fabricate one - I have seen the flashing tape around a couple of the same stores though, and thought that might be an option - I'll keep looking.
are the prefab pans very expensive, and do you know if they are typically sold in the big box stores like Home Depot or chains like TimBRMart (I'm in Canada)
thanks
-randy
Old 07-10-2008, 10:40 AM   #4
As for the door pans, check a lumber yard...84 lumber, Stock Building Supply, or similar in your area. You can always get one made at a sheetmetal shop.
Another route would be to buy a pair of handheld "seamers" at your big box store, and some roll flashing....maybe 8" wide. Both of those will probably be around 30-40 dollars, but the seamers are good to keep around(good investment). If you choose this route or are interested, I'd be happy to explain how to bend one up.
That flashing tape is really only effective if you are using windows with a nailing flange. Per your first post, silicone on the backside of the brickmould is a good bet!
Old 07-10-2008, 11:27 AM   #5
Rewards Points: 270
Thanks again Brown Dog - if my search for the sill pan products turns up empty, then I'll look for the seamer as you suggested - i've never done any work with coil stock so if that's the route then I'll definitely be back to pester for more info
-randy
Old 07-10-2008, 12:00 PM   #6
No problem. Although I just noticed an ad on the right side of page for sills..."sursill.com" is the company.
You'll probably find outh that it will be cheaper to bend your own...
Old 07-25-2008, 02:28 PM   #7
Rewards Points: 270
follow-up concern / questions
I got a local renovator shop to bend some flashing for me for my door - pretty cheap - anyway, in my travels I talked with sales guy while in one of the home renovation places - he said they never use any kind of (metal) flashing on their patio door installs - apparently they caulk the sills, and use the DAP or Dow non-expanding foam to seal the sides / top. Claiming that the silicone is enough on the bottom, and that the foam makes it completely waterproof everywhere else.
After reading a ton of stuff on line I got the impression that flashing the sill on a door was like the most important thing to do in the install. Now I have someone in the business telling be they don't bother.
Just looking for opinions...
thanks
-randy
Old 07-25-2008, 02:48 PM   #8
Rewards Points: 270
thanks
-randy
Old 07-25-2008, 03:12 PM   #9
concretemasonry's Avatar
Rewards Points: 2,594
Randy -
All you did is talk to a home renovator guy that is probably the type that does cheap "flips" on TV shows and never worries about the results.
I know of builders that will not do an install without pan flashing, even though they use certified installers instead of their own people. - there is a bottom to every barrel, and renovator uis usually near there.
concretemasonry is offline   Reply With Quote
Old 07-25-2008, 03:31 PM   #10
You need a door pan.....thats it. Water will find some way to get beyond the silicone and start eating up your flooring. Do yourself a favor...spend a little now to save A LOT later.
Old 07-25-2008, 03:53 PM   #11
Rewards Points: 270
thanks folks - yes Brown Dog I took your advice and the pan is in the back of my truck now - just looking for some sanity checks which I have found here once again
thanks all
-Randy
Old 07-29-2008, 04:05 PM   #12
Rewards Points: 270
another follow-up question - i've seen a few references here to using ice & water shield in certain window flashing applications - in my case (as mentioned earlier in this post) I'll have windows going into a wall that will not have any tyvek or other housewrap on it. I do have a pan flashing for my door (thanks again B Dog and others) but for the window I was wondering if I could use a strip of ice & water shield material (left over from the roofing work last fall) to flash the sill - and since there is no housewrap to "tuck around" the frame of the opening, maybe I could use the I&W on the jambs as well?
As with the door, an integrated brick mold on the window will be sealed (silicone) against the plywood (stained) exterior sheathing, with a bead around the edge (top and sides) to finish it off.
One day the outside will carry typar and hopefully a cement board lap siding like hardi-plank (another house down the way just had this done - sharp looking, critter proof - really nice - just ain't in my budget right now....)
thanks
-Randy
Old 07-29-2008, 04:47 PM   #13
Well, only running that I and W shield in tyhe jamb won't do a lot of good. Water can still get behind it. You really need to weatherlap the entire house for optimal performance. Just doing it in spots really defeats the purpose.
I would not bother with the I&W shield until you decide to wrap the entire house.
Old 08-02-2008, 08:57 AM   #14
Knucklez's Avatar
Rewards Points: 932
brown dog, i would be interested in learning how to use a hand held seamer to turn rolled metal into flashing.
i am residing my house with wood board & batten. i will also be house wrapping with tyvec.
i will probably need to flash my windows. and probably the doors.
can you provide detail info, or direct me to a good website or book?
thanks!
Knucklez
Knucklez is offline   Reply With Quote
Old 08-02-2008, 11:35 AM   #15
I'd be happy to tell you how I do it. If appearance is no.1 on your list though, rent a brake...you'll get a cleaner look. Hand seamers do a fine job, you just can't get that bend to be as crisp as with a brake. Email me if still interested: BJYourk@aol.com
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 12:48 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 08:30 PM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 09:24 PM
