Sill Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 04:04 PM   #1
Sill Insulation
Hello
I've got some Rigid Polyisocyanurate Foil Faced Foam Board and want to use it to insulate our sill in the basement. My plan is to use construciton adhesive to seal blocks of the foam board right to the wood of the sill. I know the foil serves as a vapr barrier so is there any problem in putting this right against the wood?
Brian
bmelanco is offline   Reply With Quote
Old 02-06-2010, 04:21 PM   #2
ccarlisle's Avatar
Nope.
Sealing is important as air can in/out there...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-06-2010, 04:31 PM   #3
Thanks. I've only done it in the past with the vapor barrier away form the wood...
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-01-2010 11:21 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
