Old 09-20-2010, 07:25 PM   #1
Sill on aluminum window
Last night we locked outself out of our house. I tried to get in through the garage window, and bent the bottom sill up. I am unable to get it to go back down, so I am wondering if I can just replace the sill, or do I have to replace the whole window frame now. The sill is aluminum, and the house has brick going up the house, then vinyl up the rest of the house. I see on the window sill that it just has a lip on the underside of it, and its supppose to slide right back inbetween the walls. Any help would be truly appreciated.
danvath is offline   Reply With Quote
Old 09-20-2010, 10:45 PM   #2
Tom Struble's Avatar
it should go right back,you may need to add a few nails to keep it positioned
Tom Struble is offline   Reply With Quote
How to disassemble aluminum clad wood window sash? JohnBinSC General Discussion 6 01-17-2011 06:59 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 09:34 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
