Silicone Caulk - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 02:10 PM   #1
Silicone Caulk
I am installing some vinyl windows and am looking for a very good silicone to use? I'm assuming I should use 100% silicone. Is GE Silicone II ok to use? any other suggestions?
Dominick
dorlando is offline   Reply With Quote
Old 11-22-2009, 04:04 PM   #2
Remodeling Contractor
It is okay but you might be better using an acrylic silicone caulk to keep the joint flexible and paintable.
Old 11-22-2009, 05:52 PM   #3
ArmchairDIY's Avatar
Were are you caulking? Interior or exterior, and does it need to be paintable?
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Old 11-22-2009, 10:31 PM   #4
This is for exterior caulking and it does not need to be paintable. An engineer friend of mine said to use 100% silicone. Isn't it pretty flexible?
Old 11-23-2009, 05:12 AM   #5
Rewards Points: 4,534
100% silicone sealant's much better'n anything else,,, HOWEVER, for best results, it should NOT be applied as caulk w/full adhesion,,, we run a strip of 1/4" tape down the jnt 1st so the sealant adheres to both sides of whatever void's being sealed,,, when any expansion/contraction occurs, the sealant's free to stretch/compress,,, lasts much longer that way,,, btw, you MUST 'tool' the sealant to force adhesion to the properly prepp'd surfac's AND shape-factor's VERY important,,, ck out the website for your supplier to be sure.
this is the same method we use when sealing jnts in conc - slabs/decks/highways,,, its VERY flexible - your engineer's 100% correct.
Old 11-23-2009, 06:53 AM   #6
Personally I prefer polyurethane, or synthetic rubber (such as OSI Quad) caulking for exterior use. Although they are a little more difficult to work with and they do have a stronger oder, but they are very elastic and adhere better to porous materials and are available in a wider range of colors.
Repairs or re-caulking with silicone is problematic because new silicone does not stick to old silicone.
Old 11-23-2009, 07:00 AM   #7
agree but if you/anyone does a 1/2-ass'd job on prep, no mtl's any good ! ! we've pump'd barrels of the stuff & NEVER had a problem so let's not blame silicone.
Old 11-23-2009, 07:56 AM   #8
Not my intention to blame silicone for anything, just a personal preference and past experiences that have made me come to this conclusion.
I should also say that most of my exterior caulking involves either cedar siding or half log siding, so this factors into my choices as well. So the wood and the need for frequent maintenance coats of stain or paint make silicone a poor choice for my particular applications.
itsreallyconc, I couldn't agree more that no material will make up for poor installation.
And the great caulk debate continues, There are so many good quality products on the market now it can be a difficult decision to make.
Old 11-23-2009, 08:08 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
As above. The three causes of caulk failures:
Poor prep work (cleaning, priming)
Poor joint design
Wrong product selection.
Most quality caulks made today will last a good long time if they are applied properly.
Good info on caulk types here:
http://www.wbdg.org/design/079200.php
Good info on joint design here:
http://www.masterwall.com/files/mw14...lantdesign.pdf
Old 11-23-2009, 09:22 AM   #10
ok, thanks for the great info. So, if I'm installing windows that are attaching to the buck strip will I need to tool the silicone after I put a bead on the buck strip? also, if there is some paint on the buck strips do i need to take that off or prime it?
Old 11-23-2009, 10:34 AM   #11
impo, no silicone sealant's worth a **** when applied to wood NOR does any silicone sealant mfg recommend it for that purpose - sorry - no idea what a buck strip is,,, would it occur during deer season by any chance when the does're watching & looking to mate ? ? ?
Old 11-23-2009, 04:11 PM   #12
ok. My engineer friend also mentioned Sonolastic 150, I guess it is a hybrid and he says it works very well. also called a pro shop who sells it and they say it is widely used. Apparently works on several substrates including wood.
Old 11-23-2009, 09:06 PM   #13
dIYHell
Rewards Points: 150
I used Sika for all my windows which seems to work well.
rocketdoctor is offline   Reply With Quote
Grout sealer before or after silicone caulk ? SPS-1 General DIY Discussions 2 07-28-2009 10:30 AM
removing silicone caulk from dryall, MDF 99BN99 Painting 2 07-12-2009 05:45 PM
silicone on silicone caulk ponch37300 Kitchen & Bath Remodeling 2 05-09-2009 09:11 AM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 09:03 PM
Clear silicone caulk used instead of plumber's putty**HELP** hummin40 Plumbing 8 02-12-2008 02:59 PM
