Silent Floor (G5) - Approximately 12" In Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 05:23 PM   #1
Rewards Points: 150
Silent Floor (G5) - approximately 12" in height
Hi all,
Working on a basement project - room sized about 16' by 14' - at the moment, and I have some questions:
1) Would this floor system be strong enough to hold the weight of drywall and framing for the ceiling of the basement rooms below?
2) Would you rather install suspended ceiling in lieu of sheetrock in the basement?
3) From the cost stand point, which option would you choose?
Thank you in advance.
oodssoo is offline   Reply With Quote
Old 10-27-2012, 05:28 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
oodssoo,
what is the size and span of your floor joists (proposed ceiling for basement). without knowing this one could not answer your question ......
the advantage of a suspended ceiling is you have easy access to plumbing, electrical and hvac should you need it. with drywall you may have to tear it down to get your access. if it were mine I'd probably go with the suspended ceiling. there are many options available to provide more pleasing looks that the typical commercial 2'x4' plain panels. check out Armstrong Suspended Ceilings on-line.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-27-2012, 05:29 PM   #3
Rewards Points: 12,858
A suspended ceiling would allow you access for any wiring, plumbing, HVAC, cable repairs or changes.
Gas Fireplace Flame Height Control chh HVAC 3 09-09-2012 12:22 PM
