Siding Trim-out Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 01:08 AM   #1
Meep!
Joe Dirt's Avatar
Siding trim-out question
Is this correct? These seams look suspect to me, but I really don't know much about it- just looks like they would let in some water. Probably not enough to worry about? Just thought I'd ask...
Joe Dirt is offline   Reply With Quote
Old 05-14-2012, 06:44 AM   #2
Rewards Points: 264
I think that needs to be repaired. Looks like it will let water in behind the siding.
7echo is offline   Reply With Quote
Old 05-14-2012, 06:48 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
water is always behind siding,corners are supposed to be flashed underneath,if it is it's not a problem as long as the bottom is open
if it's not flashed it potentially could be an issue
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
jaydevries (05-16-2012)
Old 05-14-2012, 08:18 AM   #4
kwikfishron's Avatar
Rewards Points: 208
I hope you don't mean all siding.
kwikfishron is online now   Reply With Quote
Old 05-14-2012, 12:43 PM   #5
Meep!
Joe Dirt's Avatar
Thanks... I['ll check it out and make sure it's open below at least. We're in a very tree-heavy area, so things don't get a ton of direct sun and I really don't want water anywhere it shouldn't be...
Old 05-14-2012, 06:17 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
that corner post was installed rather sloppy, it doesnt affect the water proofness of it but for looks. it should have been cut to match the slope of teh fascia board then the j channel butt into it as opposed to the j channel being cut to tuck into the sharp angle
as for keeping water out from behind the corner post the roof sheathing should have extended out past the gable end so to create more protection from water getting behind the siding up top
woodworkbykirk is offline   Reply With Quote
Old 05-14-2012, 07:13 PM   #7
Rewards Points: 208
Siding (any type) should "never" protrude past the fascia, it's a bad detail and is problematic..
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 05-14-2012, 07:19 PM   #8
Rewards Points: 13,300
That top most pice of siding was also cut to short.
Old 05-15-2012, 08:35 AM   #9
Meep!
Joe Dirt's Avatar
Yeah- while the siding looks good from a distance, it's akin to a 20' paint job on a car. Lots of shoddy detail work if you pay attention to what you're looking at.
Can I do anything to help that corner post seam, or should I not worry about it too much? I tend to over-worry about some things...
Thanks for the great replies so far...
Old 05-15-2012, 08:46 AM   #10
I would be more concerned with the J moulding sticking out then the outside corner.
I use 1/2 not 5/8 J moulding at the top of a wall.
Old 05-15-2012, 02:06 PM   #11
i do
Old 05-15-2012, 02:07 PM   #12
thats a rake the wider j is required
Old 05-15-2012, 02:38 PM   #13
usually a small return or ''porckchop'' would be used and the corner would go under it
in the op pic the j should have been longer and the corner cut at an angle it would then slide up into the j pocket after removing the small ''curl''in the j,again requiring the wider pocketed j
what you never want to do is to try and seal the bottoms of the corner
Siding trim-out question-0107021155.jpg   Siding trim-out question-0107021155a.jpg
Old 05-16-2012, 09:42 PM   #14
i agree Ron,but to be honest i never see much water issues here with a ''hollow'' ventilated type of siding like vinyl or aluminum,and there are things that can be done to help direct water to a safe exit
yes..thats blood
Siding trim-out question-0709111217.jpg   Siding trim-out question-0709111219.jpg
Gable trim detail question with pics mjzraz Roofing/Siding 9 11-06-2011 10:46 AM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-14-2009 12:16 AM
question on installing stucco siding? Rusty Bottoms Building & Construction 7 10-27-2006 03:26 PM
