Siding Trim Around Windows, Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 09:10 AM   #1
Rewards Points: 274
siding trim around windows, doors
New construction- Is there an advantage one way over the other: (I am doing window/door trim instead of shutters).....wrapping 2"x4" with aluminum versus using the 4" vinyl trim pieces? Windows have drip edge all the way around for j channel, doors have brick mold.
ugabulldog is offline   Reply With Quote
Old 08-18-2010, 12:36 PM   #2
kwikfishron's Avatar
Rewards Points: 82
I would wrap the wood before using the wide vinyl trim any day.
Don’t just C cap the trim, bend a flange in it to lay on the wall.
Turn your trim wrap into a piece of flashing.
kwikfishron is online now   Reply With Quote
Old 08-18-2010, 05:54 PM   #3
Rewards Points: 274
Donít just C cap the trim, bend a flange in it to lay on the wall.
Thanks,....please elaborate on why wood over vinyl trim??
Old 08-18-2010, 06:09 PM   #4
Rewards Points: 82
Just to many places for water to get in with the vinyl.
Old 08-18-2010, 11:15 PM   #5
Remodeling Contractor
eisert is offline   Reply With Quote
new hardi siding and windows - what have I started? aargh! derf36 Project Showcase 51 06-11-2010 06:26 PM
Interior stop trim after installing replacement windows not fitting correctly DyerWolf Carpentry 10 11-26-2009 10:53 AM
Can I frame exterior windows over siding? Wreckingbar Building & Construction 1 03-13-2009 06:32 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
