Siding Test - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 06:51 PM   #1
Rewards Points: 194
Siding Test
Are there one or more tests that would give me some idea about the current condition of the circa. 1992 Masonite siding on the second floor of our home?
sore thumb is offline   Reply With Quote
Old 06-02-2013, 07:44 PM   #2
joed's Avatar
Rewards Points: 13,298
Look at it. Poke it with something pointy to see if it is rotten.
The Following User Says Thank You to joed For This Useful Post:
sore thumb (06-02-2013)
Old 06-02-2013, 07:45 PM   #3
kwikfishron's Avatar
Rewards Points: 772
Simple, poke it with a screwdriver. If the siding is hard = good. If it's soft = bad.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 06-02-2013, 07:54 PM   #4
Rewards Points: 6,652
Tap with the handle of a screwdriver, do not poke it with the tool. You can tell from the sound difference, if the product is solid, or going bad.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 06-02-2013, 08:21 PM   #5
Rewards Points: 772
Wrong.
Old 06-02-2013, 08:50 PM   #6
Originally Posted by kwikfishron View Post
Wrong.
Wrong to poke the material, correct to tap the siding material with the handle of the screwdriver. You can tell if the material is solid or rotting, just by the sound it will make. Once you start poking, you will make the damage worse, and then next thing you know, you have large chunks of siding falling off of the house.
Old 06-03-2013, 06:04 AM   #7
Rewards Points: 772
First you start poking then you start digging and then you fix.
You can't do much with the rotten siding still on the wall unless you require the step of prolonged head scratching and procrastination, If so then I apologize.
Old 06-03-2013, 07:20 AM   #8
Rewards Points: 194
Did the light poke test this morning and the siding is sturdy. Hooray!
Thanks everyone.
Steel Siding vs Vinyl Siding ?after? Painting 4 04-24-2013 07:22 PM
Patio Cover and vinyl siding? r_halleman Building & Construction 7 03-30-2013 12:55 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
