Siding Seams Layout? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 07:31 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,288
Siding seams layout?
Where do the pros put the butts when installing clapboard siding?
Which would be visually more appealing, placing the siding so that the butts are uniform or more of a random pattern?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 10-22-2007, 08:18 AM   #2
Rewards Points: 5,336
Random for me.
Old 10-22-2007, 11:38 AM   #3
Mod / ArchiBuilder
Cole's Avatar
Random!
Cole is offline   Reply With Quote
Old 10-22-2007, 03:19 PM   #4
I have gas!
Thanks,
With the random pattern do you fit in the first course then take the remainder of that course and start the second course? How big is the smallest piece you would use?
Do you try keep each course at 1 piece if possible, such as between windows, doors, etc. or does it not matter?
I'm using fiber-cement siding if that makes any difference.
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
