Siding Repair HELP!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2008, 07:02 AM   #1
After the winter, I noticed that some of the corner pieces on my Aluminum siding needs repair. The piece on the top fell off and is missing and the piece on the bottom looks like it has moved a bit. what is the best way to repair this? I've never done any siding work? THANKS!!!!
Siding Repair HELP!!-img_0675.jpg   Siding Repair HELP!!-img_0673.jpg   Siding Repair HELP!!-img_0679.jpg   Siding Repair HELP!!-img_0674.jpg
duffers is offline   Reply With Quote
Old 04-28-2008, 07:54 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
My dad's house used to have those corners and it was pretty common for them to fall off. I always popped them back in from the bottom and then pop riveted them at the bottom. I don't know if you could begin to find a replacement for the missing piece. The stuff was made in the 50s-60s, probably by Reynolds Aluminum. It is possible to fabricate a corner from a piece of coil stock, if you have a way to bend it.
Old 04-28-2008, 01:15 PM   #3
Rewards Points: 264
Pretty much what Maintenance just said; I've got similar siding and the corners are always coming loose or off. Unfortunately I can't find anybody who makes the same size these days so I've just fabricated them out of some aluminum pieces. Once they fit snug I'll drill a small hole on the bottom side and run a sheet-metal screw in to hold it.
moneymgmt is offline   Reply With Quote
siding repair chilangopolaco Carpentry 4 04-22-2008 07:39 AM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
