#1 |
Siding repair
Recently wind took off a few pieces of siding from my house
and now I have the pleasure of reattaching it. The only problem is that the vinyl siding looks like it was attached to some sort of material that resembles drywall. Nails and screws pull right out of it. Any one have any ideas on how to fix this or is this a major project that involves replacing the exterior walls? Thanks.
#2 |
Siding repair
Pictures?
Mike Hawkins
#3 |
Siding repair
does it have a black or yellow paper on it?That would be a gypsum based exterior sheathing,pretty common, you have to find the studs to reattach the panel too
good luck with the repair |
#4 |
Siding repair
The inside and outside of the board looks like brown paper. On the outside there is a layer of felt over it and then tyvek on top of that. Finding studs is going to be a problem since they're about 24" apart and if i'm lucky i'll maybe hit one of em. Ugh my next house will definitely need to have wood walls instead of this gypsum board.
#5 |
Siding repair
you could try some coarse threaded pan or washer head screws,or even some of the products they have for hanging objects on drywall
don't tighten them too much,they will most likely just strip out put 1 every 12'' or so,if it's just a panel or so you should be ok but you have to keep an eye on it and repair this kind of thing as quickly as possible once you have some panels missing it alot easier for wind to catch it and cause more damage |
#6 |
Siding repair
how old is the house?
| Tags |
vinyl siding ![]() |
| Display Modes | |
| Adding a window - cutting through Aluminum Siding -how to repair siding to look good? | DyerWolf | Building & Construction | 6 | 12-22-2008 05:02 PM |
| OSB Panel Siding: Repair or Replace | SirDieAlot | Building & Construction | 5 | 06-03-2008 09:19 AM |
| siding repair | chilangopolaco | Carpentry | 1 | 04-30-2008 12:58 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 1 | 03-19-2005 01:55 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 0 | 04-18-2004 04:35 PM |
