Siding Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 10:44 AM   #1
the Musigician
DangerMouse's Avatar
Siding question
I have these odd areas to side today up front.
I have J-channel up and grey starter strip ready, but that cutout is baffling me.
How the heck would any of you guys do the area marked?
Thanks!
DM
Old 06-30-2011, 11:07 AM   #2
Rewards Points: 5,336
If you side all the way up the wall, how do you deal with the soffit up the gable end?
Wouldn't you install a 2x4 along the house face even with the fascia and side up to that. Then install the soffit material up the gable end?
Ron
B. Franklin 1759
Old 06-30-2011, 11:13 AM   #3
the Musigician
The problem was that the gable stuck out farther than the wall over an inch. I took care of THAT problem but this one has me stumped.
The ground to the gable is already sided.
Maybe I need to ask for a picture, or someone to edit the one(s) that I took/take?
DM
Old 06-30-2011, 11:15 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
C,mon DM, think about it.
12penny is offline   Reply With Quote
Old 06-30-2011, 11:18 AM   #5
kwikfishron's Avatar
Rewards Points: 760
I would box in the soffit similar to this (Google pic). Id also run the gable soffit first then butt the siding J up to it. Notice in the pic the gable is also proud of the main wall.
kwikfishron is online now   Reply With Quote
Old 06-30-2011, 11:21 AM   #6
Not so new
12penny's Avatar
Rewards Points: 520
Thats all well and good. Make the soffit first and then side to it.
Old 06-30-2011, 11:21 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
I type too slow.
Old 06-30-2011, 11:30 AM   #8
the Musigician
There is no venting going on there, so I do not plan on adding soffit. I was planning on just painting it white. Who's going to even look up there?
I just want to figure out how to deal with the notch. Add a piece of J-channel under the cut edge the last 18" or so on the left side and J-channel the 4" vertical drop on the right?
Thanks!
DM
Old 06-30-2011, 11:33 AM   #9
Rewards Points: 118
^ This. I just couldn't get it worded a way I thought was clear enough to follow, so appreciate Ron and Ron chiming in!
Old 06-30-2011, 11:36 AM   #10
Rewards Points: 118
One of the drawbacks though is that it will make a great hangout for bats, which makes for a mess on the ground.
Old 06-30-2011, 11:41 AM   #11
Not so new
12penny's Avatar
Rewards Points: 520
Thanks!
DM
..Yes
Old 06-30-2011, 11:44 AM   #12
the Musigician
I'm wrapping the fascia board in alum. so I don't think bats will be a problem. Nothing for them to get a grip on.
Good thought though. Although as bad as the skeeters are this year, I'd welcome as many as wanted to hang out here!
DM
Old 06-30-2011, 11:48 AM   #13
the Musigician
Originally Posted by 12penny View Post
..Yes
Kinda what I figured.... My concern was the "upside down" piece of J-channel.
But being as it's under the overhang, I just don't see that much rain getting to it. I know it looks weird, but as soon as I'm done with this place and getting more jobs, someone ELSE is going to be hired to do Hardi on the whole place.
If my budget allows it, I may even go brick.
DM
Old 06-30-2011, 12:43 PM   #14
Rewards Points: 760
You can use UT on the left side instead of the J.
Old 06-30-2011, 12:50 PM   #15
the Musigician
Ut?
Dm
Siding replacement question MeatballCB General DIY Discussions 16 02-05-2010 02:53 PM
lap spacing on vinyl siding question DangerMouse Building & Construction 4 04-30-2009 07:32 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-22-2009 11:50 PM
Siding question? Taipans Building & Construction 6 03-04-2008 06:14 AM
question on installing stucco siding? Rusty Bottoms Building & Construction 7 10-27-2006 02:26 PM
