Siding Over Stucco Over Insulation.... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 12:58 PM   #1
Siding over stucco over insulation....
The exterior of my home currently comprises a thin layer of stucco applied over some white polystyrene insulation (1" maybe) which is presumably nailed to the exterior sheeting.
There are two things I would like to do, improve the insulation and change the exterior to either siding or shingles (preferably cedar shingles). The stucco is in good shape apart from a couple of nicks here and there and one area under the patio doors (see attached picture, which also shows thickness of insulation) but the doors will be replaced in the spring and that area will either be replaced by steps or a small deck.
I was planning on taking off the internal drywall/wallboard mix, replacing the insulation in the walls, assuming there actually is some, (its an old house and you can never be sure round here) and then adding new drywall. That should take care of the insulation part. But for the outside I was wondering if I could shingle right over the stucco or whether I would have to remove it and the polystyrene insulation first, in which case I might need to rethink my indoor insulation plans.
Hankyknot is offline   Reply With Quote
Old 11-20-2012, 01:11 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
Is the whole house done that way? Are you sure that the foam is just not on the trim?
Old 11-20-2012, 01:42 PM   #3
Whole house?
Yes, well three sides are, the back wall is just plain old siding but where the nicks are you can see the polystyrene underneath along with what looks like some kind of stucco mesh.
Old 11-20-2012, 04:22 PM   #4
kwikfishron's Avatar
Rewards Points: 344
What you have is known as EIFS (Exterior insulation finishing system) which is a synthetic stucco.
I’ve seen people install siding over the top of it but I wouldn’t recommend it. I’ve seen to many issues with moister being trapped behind it and rotting walls. I’ve tore off a few houses of the stuff to find extensive damage. Not to say that you have those issues but I don‘t trust it.
Another issue with going over it is it’s very difficult to maintain proper flashing details.
Removing drywall to install new insulation will quickly let you know if you have moister problems.
kwikfishron is offline   Reply With Quote
Old 11-20-2012, 04:44 PM   #5
Thanks Ron, thats pretty much why I wanted to do the drywall and insulation from the inside. Ah well, looks like my spring project just got a whole lot bigger. C'est la vie.
Old 11-20-2012, 05:05 PM   #6
Rewards Points: 13,444
Stucco not going to hold nails and it the grade looks far to close to where the siding would have to be.
Can you take a picture that's not so close up?
Old 11-20-2012, 05:52 PM   #7
Rewards Points: 344
It’s not stucco Joe, look at the first picture. You can defiantly nail through it and get to wood.
You almost need to encase the house in a bubble when tearing it off. Any wind at all and those poly beads and chunks end up are all over the neighborhood.
Proper way to Insulate and stucco a wood siding house?? clone477 General DIY Discussions 5 01-20-2011 09:47 AM
Mounting Hose Reel on Stucco Siding xquercus General DIY Discussions 5 07-03-2008 12:00 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
