Siding Over A Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 06:52 PM   #1
Siding over a door
I'm trying to get rid of my undersized storage closet in the carport and create a much larger laundry/pantry area. The door on the left will be removed and I plan to put a window in the wall somewhere. My original idea was simply to match the brick, but I've been told that this brick is no longer made (in my area at least). Given that, I was thinking about hardi-board or a vinyl siding product. T-111 even crossed my mind, but I'm not sure I want to do that.
The house is stick framed with a brick veneer. The house is in GA and the wall on the right is west facing. It gets wicked hot in the afternoon in the room adjoining that wall so I was thinking I might side that too to get some insulation benefit.
Should I remove the existing brick first or side over it? If I the brick down, what do I do about the corners (where the brick picks up again)? If I leave it up, the same question applies, what should I do at the outside corners? Thanks in advance.
former33t is offline   Reply With Quote
Old 02-26-2008, 08:27 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Quick/basic answer: My suggestion would be to install wood furring strips vertically at 16 OC using tapcons, and construction adhesive. (Install rigid foam between the furring strips, if using vinyl). Install PVC (composite) corner boards/trim boards (at corners). Then install siding material over.
Last: seal all siding/trim work as needed, dependant on the materials used/installed.
- Build Well -
Old 02-26-2008, 08:41 PM   #3
PRO Siding Windows Roofs
How bout this? Kinda pricey though at $500/sq
http://www.nichiha.com/prod_brick.htm
PKHI is offline   Reply With Quote
Old 02-26-2008, 09:37 PM   #4
electrical contractor
Rewards Points: 150
Do not side over that door, just started on a remodel in a church in GA where a door was bricked up on the outside, and paneled over inside, termites found it and did major damage to it and everything around it. My guess covering it put it in the dark making a lovely home for termites. I would remove the door frame out with treated lumber and then install siding, but thats just me.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-27-2008, 05:20 PM   #5
wire_twister, I suppose I should have been specific that I wanted to side over the existing door opening not the door itself.
AtlanticWB, thanks for the good advice.
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 05:55 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
