Old 12-12-2012, 12:01 PM   #1
Siding needs replaced
We have noticed some leaks around the nails that hold our siding on. How we have lived in this house for 40 years with no problems is beyond me. My husband believes the siding has started to rot, producing these leaks. Its T-111, and was put on in the eighties. It is the type that is in 4' x 8' sheets with trim between each sheet. Would it be best to go back with the 4' x 8' sheets, or try a new kind of siding?
The 4x8 sheets are cheapest and easiest to apply, but is there a type out there that would be better?
Its a mobile home, so we cant do stucco or stone or brick
Texas Couple is offline   Reply With Quote
Old 12-12-2012, 12:12 PM   #2
Got a picture?
I just hate T-111. Lack of proper maintance would be the main reason for premature failure.
The least expancive way and least amount of future maintaince would be to wrap the house in house wrap, build out the window and door trim, wrap the trim in coil stock and cover with vinyl siding.
Old 12-12-2012, 12:28 PM   #3
here is the siding, the dark sliver in the middle is where its leaking
Old 12-12-2012, 12:29 PM   #4
what is coil stock
Old 12-12-2012, 12:35 PM   #5
How did you post this photo?
smacman7 is offline   Reply With Quote
Old 12-12-2012, 12:39 PM   #6
its a JPEG i posted it as an attachment
Old 12-12-2012, 12:44 PM   #7
I am just not seeeing any attachment button... only the insert image which asks me for a web address???
Old 12-12-2012, 01:14 PM   #8
beside Post Quick Reply there is a button that says Go Advanced, click that and then click the paper clip icon to attach
Old 12-14-2012, 02:22 AM   #9
I believe by "coil stock" he is referring to metal coil on a roll. Guys use a metal brake to make bends to go around brick mouldings etc. then alittle bit of caulking. Basically a bunch of different color options.
r.mills is offline   Reply With Quote
Old 12-14-2012, 08:36 AM   #10
AHH, SPANS!!!
There is a version of the T 1-11 out now that is made out of fiber cement. It is not as thick as standard T 1-11, especially old T 1-11 swollen from moisture absorption. if you were to tear off the old siding the new stuff would be up to 3/8" less in thickness so you would have to figure that difference in when reworking the exterior window trim and door trim. At this point I'm not sure if the new fiber cement stuff would last as long as just putting standard t 1-11 back up but in theory it seems like it would last longer if it did not de laminate. you could also possibly use the old t 1-11 as wall sheathing and go over top of it with a new siding of your choosing...
hand drive is offline   Reply With Quote
Should I demand this be replaced? (Regarding Siding Job) steve-19 Building & Construction 9 07-11-2012 07:46 PM
certainteed cement siding cracking! wichitawings Building & Construction 23 11-04-2010 07:55 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
