Siding Inside Corners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 09:53 PM   #1
Hi,
I just had new siding put on an addition and the old part of the house. I noticed 3 inside corners where the siding guy used a single J-Channel piece and then slid the other siding behind the back of the J-Channel. So, I can see building paper (Tyvek) in the inside corner when I look down one of the sides.
When I brought it to the installers attention he said that is how it is normally done but he can put some type of "Piece" in there to cover it up.
1) Is this how it is normally done for inside corners? Is there a piece that will cover the explosed inside corner?
2) Also, they used J-Channel for the bottom instead of a starter strip. I think because the siding sites on the foundation wall in some spots (old 80 year old house).
scott j is offline   Reply With Quote
Old 02-25-2010, 08:33 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
post some pics... but no the installer should have flashed the insidecorners with metal over the tyveck,regardless of whether he used j or an inside corner trim
Tom Struble is offline   Reply With Quote
Old 02-25-2010, 03:07 PM   #3
cornerfix
I plane 2x4's down to 1 inch -then rip one to 2-1/2 inch- put them together to form an inside corner having the same dimension from the inside. paint both front and back to insure a good seal. Install in the corner and place the J- channel on the edge and you should be good to go.
James Dunn is offline   Reply With Quote
Old 02-25-2010, 06:03 PM   #4
don't do thattell your installer you want the corners flashed like any vinyl install manual shows
Old 02-25-2010, 06:16 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I second everything that Tom said.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-03-2010, 11:20 AM   #6
Attached Picture
Thanks guys. I attached a picture and you can see the TYVEK in the corner.
So all of the siding has to come off and done again in the corners? I was thinking there is a piece that can snap into the corner to cover it up.
Siding Inside Corners-siding-corner.jpg   Siding Inside Corners-siding-corner2.jpg
Old 03-03-2010, 12:17 PM   #7
MJW
To do it right, Tom is correct. Although the Tyvek, if not ripped, will keep out water. Honestly, I wouldn't worry about it too much, especially if the corner is somewhat protected. It probably has more protection now than it ever has.
MJW is offline   Reply With Quote
Old 03-03-2010, 12:27 PM   #8
Yes MJ
This is a deep corner for a Furnace Chimeny. I will post pics of the other chimney where you can see the TYVEK much easier (new side of house).
Is there a pice that can go over this? The siding guy said he had one but I haven't found anything like this.
Thanks Again. They need to have a "Send a Beer" icon here.
Old 03-03-2010, 02:35 PM   #9
To install the siding properly an inside corner should be used. And yes the siding on both walls must be removed to do this properly. Make him do it correctly.
DEKAN is offline   Reply With Quote
Old 03-03-2010, 03:56 PM   #10
MJW
What if an inside corner is not available? What if the siding is steel? There are no inside corners. I personally think inside corners don't look as good as J channel.
Old 03-03-2010, 05:57 PM   #11
Siding was vinyl. Contractor v home owner on looks.
Old 03-03-2010, 07:30 PM   #12
MJW
Not all vinyl siding has inside corners available.
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
