Old 08-14-2007, 12:27 AM   #1
weekend warrior
siding on furred wall, foam in the voids?
I furred out a 20x10 wall on my house with 1x's. I plan to apply vinyl siding soon but was wondering if I should fill the voids in between the 1x's with some sort of stiff insulation/foam to give the siding a nice backer.
The 1x's are 16" o.c.
johnny331 is offline   Reply With Quote
Old 08-14-2007, 12:34 AM   #2
I Would not worry about giving the siding a backing if insulation is not an issue. 16 centers will be fine.
warnerww is offline   Reply With Quote
Old 08-14-2007, 01:10 AM   #3
weekend warrior
well the vinylsiding.org manual says:
"when installing furring strips, take appropriate measures to establish a smooth continuous surface"
and it also said that you can't just apply it on bare studs... which is sort of like floating it on the furring strips, no?
Old 08-14-2007, 07:19 AM   #4
Agent 000
SecretSquirrel's Avatar
Well then, put some 3/4" Styrofoam in there and let's get on with it.
SecretSquirrel is offline   Reply With Quote
Old 08-15-2007, 05:48 PM   #5
weekend warrior
alright alright, just wanted someone to say NOOOO so i could save on tuff-r. no biggie, gotta do it right.
Leaking Wall, even with Siding art2670 Building & Construction 4 07-24-2007 07:53 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
