#1 |
Siding fix it question
Long time lurker, just joined and decided to post up a question
I want to get rid of the fake shutters on the exterior of the house, if I do that, the window sill will stick out past the window and look out of place, whats the best way of cutting it out and placing in a piece of hardiplank?
#2 |
the Musigician
don't you mean 10 or more pieces? that shutter will leave a blank, un-sided wall behind it when you pull it off.....
the multimaster or dremel should cut the sill off though. DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
The shutter is placed over the top of the siding, one reason why I'm thinking of taking it on since it won't be as bad as replacing all that siding
#4 |
BUILDER / REMODELING CONT
you will need to remove two pieces of siding. once removed you can do this with a good sharp hand saw.The good old fashion way.The other piece would be under the sill. BOB
#5 |
That makes sense but I guess one of my main concerns was getting the pieces off, since they're blind nailed how do people get pieces off and reinstall a new piece without working from the top down? I've put siding on before on an old house, but never had to repair or replace a single board, thats where i'm lost
#6 | |
Siding fix it questionQuote:
#7 |
you could also use a slate ripper you could probably rent one.You slide it behind the panel hook it around the nail and bang it down with a hammer on the strike surface works great.Replace the hardi you will have to face nail use ss siding nails and touch up the heads
#8 |
gravity always wins
When you take the shutters off, the siding under them is not gonna be faded like the rest, so be prepared to have two different colors (unless you like stripes).
#9 | ||
#10 |
typically you would drive the face nail head flush with the siding but with the small pcs your going to be replacing you could probably sink the heads a little lower and use some exterior spackle sand it smooth and paint
| Display Modes | |
| Dumb Siding question | 1610 CUB | Building & Construction | 4 | 08-23-2008 05:08 PM |
| Vinyl siding question? | kcrossley2 | Building & Construction | 5 | 12-18-2006 06:20 AM |
| Siding: Cement Vs. Cedar | Grumpy | Remodeling | 5 | 03-19-2005 02:07 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 1 | 03-19-2005 01:55 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 0 | 04-18-2004 04:35 PM |
