Siding Course Layout. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2008, 06:57 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
What's the most variability I can make siding course adjustments before it gets noticeable?
I'm now starting my siding project and have 3 courses laid out with a 4" exposure. I've got a space of 19 1/8" before I get to the trim on the bottom of a bay window. I was thinking I could space it out over 5 courses with spacing 3 15/16", 3 7/8", 3 13/16", 3 3/4", and 3 3/4". Is that acceptable or do you think a discerning eye would be able to detect the spacing change?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-21-2008, 09:50 PM   #2
Custom Cabinet Maker
am not a siding guru but sounds ok however where is that going to break at the TOP of the window? I usually drive myself nutz with this LOL but check to see if it also works to the top, if not then I might try to adjust over the height of the window also. On shakes I can usually move 1/8 to a 1/4 per course without much noticeable results.
skymaster is offline   Reply With Quote
Old 04-23-2008, 10:31 PM   #3
remodeling pro
That is the way it is done. The spacing on weatherboard had always been "cheated" to make the boards line up with the heads and sills of the predominate sized windows.
troubleseeker is offline   Reply With Quote
Old 04-24-2008, 06:37 AM   #4
I have gas!
So what do you think the largest variance you can have between 2 courses and overall between all courses?
Old 04-26-2008, 10:13 PM   #5
remodeling pro
With the narrow revels you describe, I would keep course to course difference to 3/16" or less if possible. Again, with the narrow reveals, I think any total differences more than 3/8" will become noticeable to the average eye. Unless I misunderstand your description, you should be fine.
Old 04-27-2008, 07:00 AM   #6
I have gas!
I sided through this section and discovered that course layout is much more forgiving than I thought. You really have to look hard and only after someone tells that there is a spacing change to see that there is a change.
Siding seams layout? Clutchcargo Building & Construction 3 10-22-2007 02:19 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
