Old 05-21-2008, 05:50 PM   #1
Siding Corners
I am building a 10' X 12' shed on which I plan to use 3/8" particle board (SmartLap) primed lapboard siding.
What options do I have for the corner treatment?
I am not afraid to mix composition types.
rbul1 is offline   Reply With Quote
Old 05-21-2008, 11:12 PM   #2
Moderator
Termite's Avatar
Siding Corners
I'd use LP smart trim in 5/4 thickness.
Old 05-22-2008, 10:46 AM   #3
Siding Corners
Thanks for the recomendation.
I plan to blind nail leaving a 'reveal of 4" '.
You seem to have had experience with this (or similar) products,
what type nail do you suggest?
Thanks again
Old 05-22-2008, 12:21 PM   #4
Moderator
Termite's Avatar
Siding Corners
I'm assuming you're talking about the siding, not the trim.
Check LP's website for the siding's installation instructions to be sure, but I'm thinking galvanized 8's would probably do the trick. Something with a ring shank would be even better if you can find galvanized ones. Just be sure they penetrate the studs and not just the exterior sheathing of the structure.
Old 05-22-2008, 02:27 PM   #5
Siding Corners
you can nail 1x3 in each corner and then nail 1x4 over top and then slide the lap up against it and the 1x4 will cover the seams...Good luck
robocop2269@verizon.net is offline   Reply With Quote
Old 05-22-2008, 05:13 PM   #6
Moderator
Termite's Avatar
Siding Corners
Same thing I'm talking about...But described better! I'd also suggest installing strips of 15# felt vertically at the corners behind the trim and the joint between the lap and the trim boards.
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Pressure washing painted houses nightman General Discussion 6 02-05-2008 09:23 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
