Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2008, 04:54 PM   #1
Siding
I am planning to put certain teed shakes all around the house. I have one contractor that will install the foam board all around and another that suggests to put ty-vex all around without the foam board. Which way should it be?????
Skids is offline   Reply With Quote
Old 03-14-2008, 06:24 PM   #2
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
It could be either way.
While the foam board(depending on the thickness) will offer extra insulation value,the Tyvek is designed to cut down on wind penetration through cracks in plywood.
If this siding is going over the sheathing and you have sufficient insulation in your wall cavities(2x6 construction with R19)then the tyvek would be better.
If you are going over existing siding,than the foam board can be used as a leveling system for the new siding.
oldfrt is offline   Reply With Quote
Old 03-14-2008, 08:35 PM   #3
i would worry about the foam board especialy if it is clad with alluminum. the foam board tends to condensate on the side against the home. i would go with just tyvek. the insulation value of foam board ist woth the cost also. if the walls a properly insulated the foam board wont do much, just remember you loose the most heat through the windows, doors, and underinsulated attic.
chris
http://www.homebuildingclinic.com
hmbuilder is offline   Reply With Quote
Old 03-14-2008, 09:05 PM   #4
Building and plumbing
USP45's Avatar
Rewards Points: 150
We use foam boards when there is such an uneaveness in the old siding that installing the new would look terrible. We install the foam board and now we have a nice flat surface.
Not only does Tyvek stop air from comming in, it allows the house to breath, sort of a one way vapor barrior, lets moisture out, but not in
USP45 is offline   Reply With Quote
Old 03-15-2008, 08:25 PM   #5
siding
Thank you all for the reply. I feel much better about my contractor..
Happy building,
Skids
Pressure washing painted houses nightman General DIY Discussions 6 02-05-2008 08:23 AM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
