Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 07:03 PM   #1
siding
can you hang sideing with a 16 guage 2 and a half inch finish nail?
dataja01 is offline   Reply With Quote
Old 12-07-2012, 07:06 PM   #2
Rewards Points: 13,300
No form of siding I've ever heard of is installed with finish nails.
Care to let us in on what type siding your trying to installed?
There's only a few dozen differant types.
Old 12-07-2012, 07:28 PM   #3
I hired a contractor to build a room on to my house. He did a few things that I had to fix.
I noticed that he put the brown pressed board siding from home depot. Looks like wood.
4 foot by 8 foot sheets. He used 16 gauge 2 1/2 inch galvanized air gun nails to put on the siding.
I was wondering if that will hold. Should I re-nail the siding?
Old 12-07-2012, 07:58 PM   #4
funfool's Avatar
Rewards Points: 534
Is not ideal, not a lot of holding power for the product in use.
I would prefer a 6 penny ring shank, for sofits we use a staple gun.
Staples seem to have more holding power to me, but leaves a bigger hole to caulk before paint ... but up high and looks fine from the ground.
For siding the 6 penny ring shank in my framing gun.
All that being said, I have used my finish gun with 2 1/2 nails many times for siding.
Gable ends on a gambrel roof and all 1x8 pine, was what nails were requested and held up fine.
I have used it for repairing patches in the siding you describe and it does hold.
Just not my first or second choice.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
dataja01 (12-07-2012)
Old 12-07-2012, 10:05 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
find all of the studs in the wall and re nail the siding with 2 1/2" spiral siding nails every 16" or 24" apart in the field and 8 to 12" on the seams. Was wood sheathing added to the wall behind the siding ?
hand drive is offline   Reply With Quote
Old 12-08-2012, 07:21 AM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the only time a 16 gauge is acceptible for installing siding is with wood siding for underneath windows, doors and soffit when the final course is 2" or less and installed not only with the gun nails but with a bead of caulking to act as adhesive
the combination of wind and rain causes too much chance for movement and the siding coming off. you need nails with a full head on them
woodworkbykirk is online now   Reply With Quote
Old 12-08-2012, 08:06 AM   #7
Wrong nails and wrong material for the siding in my opion.
Brings back memerys of the nightmares dealing with masonite siding.
Sounds like he took the cheap way out.
Does it happen to be Smart Side brand siding?
http://www.lpcorp.com/smartside/lap/resources/
Old 12-08-2012, 11:32 PM   #8
Registered User
Rewards Points: 5,236
The fasteners required, spacing, max. wind speed, etc., all change per location; http://publicecodes.cyberregs.com/ic...002_par005.htm
Where are you located?
Gary
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 07:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
