Siding For 12x12 Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 01:09 PM   #1
Siding for 12x12 shed
I have framed a 12x12 shed and I am about to put the siding on it, but can't decide what siding to put on it. I was at Lowes and saw some siding that said it was for exterior paneling for sheds and garages with a barn style finish. I looked at the back and it looked like the material pegboard is made out of, I guess it is OSB. I was just wondering if this would work if I sealed it and painted it. It is only around 18 or 19 dollars a sheet. If not what would be best. I have heard t1-11, but some people say it will go bad after too long, but I just don't have the money to go with vinyl siding. I live in west texas so there isn't to much moisture just wind. Thank you for the help in this project.
tcfls2 is offline   Reply With Quote
Old 02-15-2010, 01:47 PM   #2
General Contractor
go for it
I don't know the exact Lowe's product you are referring to, but it sounds like what is called T1-11 today. HD sells LP's Smartside version.
In any case, I have repaired a fair bit of T1-11 up here in the wet Pacific Northwest. However, I have been told that much of the failure goes back to poor installations. It's a cheap product, and it's meant to speed up the building process. Naturally it was the choice of not just good builders but also many builders who were trying to knock em out as fast as possible.
Be very careful to install exactly as instructed by the manufacturer, use the right flashing and the right caulk in all the right places, pay attention to gaps and separations from other materials, and treat your cut ends, even if it means you can't install it as quickly as you would like. It will last long enough.
Good Luck,
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
Old 02-15-2010, 02:14 PM   #3
Rewards Points: 264
I check craigslist.org quite a bit for supplies on small jobs like that. Looking here around Detroit, found a few square of vinyl siding from people at $40/sq. That's even cheaper than what you're finding at Lowe's, granted you'd need starter strip, corner channels, etc.. Just a thought!
moneymgmt is offline   Reply With Quote
Old 02-15-2010, 02:19 PM   #4
Rewards Points: 212
There's info on T1-11 here
http://www.construction-resource.com...ead.php?t=1333
orange is offline   Reply With Quote
Old 02-15-2010, 02:56 PM   #5
I think it is masonite that I was looking at. I have read some on it and they say as long as you seal it good it will last.
Old 02-15-2010, 03:16 PM   #6
Rewards Points: 212
I would definitely NOT use masonite on an exterior building exposed to the weather.
Old 02-15-2010, 04:37 PM   #7
If I do go with the smartside T1-11 siding is it ok to caulk any openings in the joints or any spaces as long as I have a vent on the roof.
Old 02-15-2010, 08:40 PM   #8
Personally I would consider pricing out siding that matches your house. It isn't that much more expensive and if you get vinyl you get a lot more years than a painted siding or paneling.
TANC is offline   Reply With Quote
Old 02-16-2010, 07:57 AM   #9
Well my house is brick, but I think I may look around on craigslist to see if I can find left over vinyl from big jobs. Thank you for all of your help.
Old 02-16-2010, 09:04 AM   #10
I would side each side diff
The older I get the better I was
Old 02-16-2010, 09:21 AM   #11
General Contractor
seal it
tcfls2,
Just to reply to your question, if you did use a SmartSide type siding, you should seal all the edges.
If you need ventilation, install venting.
Good luck,
Rory
Portland, OR
Old 02-16-2010, 03:36 PM   #12
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Good Luck,
Most of these siding products are very specific in regards to nailing procedures. You can't bury the nail heads. Especially toward the bottom of the sheet. I've seen ton's of siding installed incorrectly and the manufacturers are paying the price in class action law suits.
Kevin
Kevin M. is offline   Reply With Quote
Oriented Strand Board (OSB) as Shed Siding Cuc Tu Roofing/Siding 23 02-19-2014 12:23 AM
Shed siding NateHanson Building & Construction 5 10-27-2011 12:16 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
