Old 07-04-2007, 07:00 PM   #1
Sidelight - Cannot find vinyl trim
The trim on the outside of my sidelight is damaged from the heat. This is the trim that goes around the sidelight window and has bolts that go from the inside trim and attaches to the outside trim (the one I want to replace). Does anyone know who might sell replacement trim or know who manufactures this type of sidelight?
lrichards is offline   Reply With Quote
The Following User Says Thank You to lrichards For This Useful Post:
dmjohnson (08-26-2010)
Old 08-28-2008, 05:30 PM   #2
the Musigician
DangerMouse's Avatar
a photo would help a lot here....
DM
Old 08-28-2008, 05:42 PM   #3
Moderator
Termite's Avatar
The corner of the glass will often be etched with the unit manufacturer's name. It is sometimes a very light etch that is hard to see. If you can determine the manufacturer, you'll have completed step one. Until you know who made that window, you're chasing your tail. Odds are that the door and the window were a unit, so check the door jamb and hinges for the manufacturer name as well.
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Vinyl siding brickmold rjniles Building & Construction 1 02-05-2007 11:55 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
