Side Walks In Community - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 05:31 AM   #1
Side walks in community
We are replacing sections of pavement and want to know how this product compares to the regular PSI 3000. Will it bond next to the existing and the cost difference.
S P Baker is offline   Reply With Quote
Old 01-30-2013, 06:24 AM   #2
DIY staff
Rewards Points: 7,174
I think you left something out of your question----please read and the add the missing parts---
Old 01-30-2013, 09:52 AM   #3
Rewards Points: 4,642
if you're replacing sections of s/w, you don't want the new to bond to the old except in rebuilding-a-joint instance,,, IF its likely you're referring to apron/vest store bagg'd conc mix, it's fine - compressive strength should be listed on the bag,,, what will lower the strength is adding too much water
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 02:51 PM
Kenmore side by side. Freezer way too cold, Fridge is barely cold Steevehu Appliances 4 08-14-2011 10:32 AM
Durock installation in bath, what side goes out? smcmurrey Building & Construction 8 12-12-2010 06:48 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
GE Side by side water dispenser not working cfinchapex Appliances 3 09-19-2009 10:39 AM
